5 members (Rustnut, Donf, Gdads51, Charles in CA, lumbersawyer), 63 guests, and 3 robots.
Topics128,203
Posts1,057,414
Members48,471
#1613270 10/14/2026 4:04 PM
Are the valve spring caps from a 1953 low-pressure 235, compatible with modern valve springs for a 1954 or 55 235 head.
I found it The Master Parts Cat. engine cross section from 1953 through 1957. Yes, its the same. Part number 0.309. valve cap.
Shade Baby
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
Good work, Grasshopper. wink
That 0.309 number is just an index number pointing to all "valve spring caps". To make sure the same part is used on both '53 and '54-5 check that the same part number is listed for both.
Good catch, knowing you guys is like going back to the school of hard knocks. Lol
From what I see it looks good to me attached is some info. Please advise.
Shady
"Back In Time"
Follow in the DITY
I've used small block Chevy V8 valve springs, spring retainers, and split keepers on stovebolt engines with no problems- - - - -frequently. They're cheap and plentiful. Even the V8 exhaust valves will interchange with no problems and they're available in stainless steel.
Shady
"Back In Time"
Follow in the DITY
Some of the early spray-oiler engines, 216s and I believe 235s, had an umbrella-shaped sheet metal cap that fit over the top of the valve stem and the spring retainer. I've seen them on late 1940s engines.
