2 members (78buckshot, cmayna),
111
Mod | | | Forums66 Topics128,279 Posts1,058,593 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2026 Posts: 5 'Bolter | | 'Bolter Joined: Jul 2026 Posts: 5 | Well, I appear to be stuck. I can’t find a source for main bearings for my 1954 235 overhaul. They are the dowel type. .010” or .020” under hasn’t been determined yet. We wanted to see if the bearings were even available before grinding. The machine shop ran into a dead end as did Chevys of the 40’s.
Any suggestions or anyone have a set? I’m willing to modify to the other type of bearing like “Hotrod Lincoln” talks about on the forum, but I don’t have enough history on the site to allow a PM to him. I don’t know enough to know if that mod is even possible.
Darn it! It was going pretty smoothly until this hiccup. No cracks, never been bored. Ran great before teardown, just high oil consumption. Basically just worn out.
Thanks for any info! | | | | | Joined: Jul 2026 Posts: 5 'Bolter | | 'Bolter Joined: Jul 2026 Posts: 5 | I just submitted a post about searching for main bearings (dowl type) for my 235 overhaul. The message is waiting for moderator screening. I can’t find them anywhere. I don’t have enough posting history to PM a member or I would go right to Jerry (Hotrod Lincoln) and inquire about modifying to the non-dowl bearings. Any info or help sourcing main bearings would be greatly appreciated!
| | | | | Joined: Apr 2004 Posts: 5,100 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,100 | Becker, we'll ok your posts as soon as I can. You've got 2 down. 2 more to go. Make them soon and I'll jump on them.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: May 2015 Posts: 11,282 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,282 | Modifying for tab type bearings is pretty easy. A dremel tool can make pretty quick work of grinding a notch in the block and bearing caps. Don't know if the later 235 bearings are available to fit the 1954 235's though. Good luck on your search.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2023 Posts: 284 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 284 | Try The Filling Station. I just purchased some 30 under for my 1954 235. They are pricey, but what are we to do.
Good Luck Shade Baby | | | | | Joined: Jul 2026 Posts: 5 'Bolter | | 'Bolter Joined: Jul 2026 Posts: 5 | Shade Baby, thanks for the lead! At least now I know I can get them, even if I just have to send mine and get them ‘restored’ and ‘resized’. And, no, I didn’t know that was a thing. Daniel said it’s no problem. I’ll do a follow-up to add to the 235 knowledge base when I have a solution. | | | | | Joined: Oct 2019 Posts: 510 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 510 |
| | | | | Joined: Feb 2004 Posts: 29,960 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,960 | The simplest, and least expensive option is to grind divots into the block webs to use the late 55-61 main bearings. Every other dimension is the same- - - -inside and outside diameter, width, oil hole placement, thrust bearing width, etc. Even the lower bearing shells have the same dowels included. The only reason for the upper bearing modification is to make it easier to change main bearings with the crankshaft in the engine. Make about 2 more posts and you'll have access to the private message option. Jerry
| | | | | Joined: Sep 2019 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 168 | If you will look at the Parts for Sale listings you will see the listing for “Cleaning Out the Shed “, under it you will see where I have listed the ‘55-‘62 main bearings in standard size.
I invest my money in precious metals, mostly rust!
| | | | | Joined: Feb 2004 Posts: 29,960 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,960 | www.ebay.com/itm/315048475873?www.ebay.com/itm/146674033705?These are both available on Ebay as of 10 minutes ago. It's less than a 30 minute job to make them fit your engine block. Jerry
| | | | | Joined: Jun 2018 Posts: 101 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 101 | Just a +1 vote on Jerry's solution. Took longer to carefully mark where the notches needed to be then to do the actual grinding. 30 minutes is generous on time though.
1954 3600 Stakebed non-original engine out of a '55 passenger car with powerglide
| | | | | Joined: May 2015 Posts: 11,282 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,282 | 30 minutes or less is what it took me to put those notches in. Just use the new bearings as a guide for the notch location. Even if you get a little wide, it's no big deal.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2026 Posts: 5 'Bolter | | 'Bolter Joined: Jul 2026 Posts: 5 | Thank you everyone! The crank is at the machine shop. I told them to grind it and I would address the bearings when I see how much they had to take off. I found some .030” bearings but didn’t want to commit to that much grinding if it didn’t need it just to get bearings. I’m going to grind the notches like several of you suggested and install the later bearings. Jerry, if it’s OK, I’ll PM you when I get enough history and get some guidance. Much appreciated gentlemen! | | | | | Joined: Sep 2009 Posts: 6,228 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,228 | Bucker your next post should come through without needing moderation. Do that and you'll see your status under your member name change to 'Bolter. Then you're free to PM Jerry and anyone else you care to.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jul 2026 Posts: 5 'Bolter | | 'Bolter Joined: Jul 2026 Posts: 5 | Well, I got the engine from the machine shop. The bore went .030” over. The crankshaft mains and rod journals went .020” under. Rod bearings were no problem, but I still had to find the mains. I looked on eBay but didn’t really want to get stuff from Turkey or Great Britain. So after getting the in-depth knowledge from the brainiacs here, I decided to go with the later model mains and file the notch for the tab. And wouldn’t you know, AutoZone had the darned things. $116+tax and shipping. Had them in 2 days. Painted the block and head this morning and fit up the main bearings this afternoon. As Jerry and several others said, it was a no-brainer. So far it works great. Plastigage next, then I can get the rest of it bolted together. Again, thanks everyone for the info. I hope to be able to return the favor many time over. | | | | | Joined: Feb 2004 Posts: 29,960 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,960 | There's another approach that eliminates the scarce and pricey stovebolt main bearings altogether. Using a set of good to fair condition original bearings, they're permanently attached to the block and main bearing caps with flat head brass machine screws, then the soft metal lining is line bored/honed to fit a set of main bearings for a small block Chevy 400 V8, leaving just the steel backing in place. Then the crankshaft is reground to fit the smaller diameter bearings. There are two advantages- - - - -the SBC 400 bearings are inexpensive and plentiful, and the crankshaft main bearing journals and block bore is the same front to rear. The original #3 bearing thrust flanges position the crankshaft in the correct front/rear location. As an added advantage, the smaller diameter mains also reduce turning effort on the crankshaft, lowering internal power loss. Jerry
