5 members (TUTS 59, oldieoldie, greenie-reddy, cmayna, Wayne67vert), 121 guests, and 5 robots.
Topics128,184
Posts1,057,195
Members48,465
#1612935 10/09/2026 6:47 PM
Finally putting the rear back together. New spring eye bolts and bushings, shackle kit. Question #1 - Per picture It appears to have bolts that must come from the bottom into the top of the upper half of the casting. When I took it apart, there wasn’t anything holding the two halves together and holes were plugged with grease/dirt. I’m assuming they must be important. Question #2 - I have not messed with the torque tube at all and hope I don’t have to, but how much slop/ fore and aft is in the driveshaft when measuring on the springs for final bolt down. Is it a spline shaft slip joint with leeway? From the wear marks on the springs I can say they weren’t even close to straight and there doesn’t appear to be any real alignment other than measurements and tightening as the casting has a pretty good sized slot. Loosen both sides, measure for evenness and tighten? And yes there another casting with ears for the U bolts to help mount the helper springs with other u bolts.
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
37 GC #1613091 10/12/2026 1:13 AM
Larry: what you have there is a spring seat. The holes you point to are threaded, correct? Look at the bottom of the bottom piece and you will see two holes that line up with the threaded holes in the top piece. Two macine screws come up from the bottom piece and thread into those holes to hold the two pieces together. Once put together they should fit the axle housing and they should barely move on the housing, they should have a slight drag. Then when you line up the axle with the spring seat there is a hole in the bottom center that goes over a dowel that sticks up from the center of the spring, then the U-bolts secure the spring seat to the leaf spring. Pre fit the spring seats (both pieces screwed tightly together) on to the axle housing and if there is too much play you should get an idea of how much has to be taken off so the spring seats will fit with a "slight drag." If they are too loose the use of a file (I used a bastard file as it takes more off) is used on the mating surfaces of both halves to remove the excess metal in order to get to that "slight drag" feel. If you have to file them do it in steps, file a little, put them on the axle, check for play, and so on until you get the slight drag.
I have a '38, HC, and have rebuilt the axle-torque tube, twice within a month, I wasn't pleased with something on the first go around and did it again.
I have extra used screws that hold the spring seat halves together, four of them, if you are interested.
I have extra siightly used (60 miles on them) carrier and pinion bearings if you feel brave enough and crazy enough to rebuild the axle.
The Ring gear is riveted, not bolted, to the carrier, and this was done from '37 '38 and '39 half and three quarter ton trucks, so there is no replacing the ring and pinion gears (easily).
The '37 and '38 axles are the same, the casting number is 377707.
Not exactly a quick reply, however I hope this information helps you.
Later,
Glen
1938 half ton pickup
Thanks Glen, cleaned it all up, turned out to be 7/16/18 and a 2.5” bolted flush through the two halves and added a new grease zerk. All is good with that now but now it appears the torque tube is sprung. Off about an inch from side to side where it hits the leaf springs. Not much in the manual but I loosened the 3 bolts to adjust but haven’t gotten any movement yet. Initial appearance the rear looks in pretty good shape. Replaced the outer bearings and seals. Passenger side was leaking onto the brake. Still had the leather seal. Also is the higher gear 3.82.
Larry
37 GC #1613176 10/13/2026 12:15 AM
Larry, So you have the 3.82 ratio, I always see it listed as an option and this is the first I have heard of it existing. I have the 4.11 so my comfortable cruising speed is 35, maybe 40. What kind of cruising speed can you get, close to 50? I've done 50 but man is that engine screaming, roughly turning 2500 rpm's.
I'm trying to picture your torque tube being sprung and what's off an inch from side to side, the three bolts? is the axle housing okay?
Later,
Glen
