Selling my last set of (46) clips for the 1955-59 window trim moldings. I had these clips made 20 years ago, they are an exact replica of the original clips. They are a perfect fit for the OEM moldings, if you have repro moldings they will require a shim made out of milk jug plastic...the repro moldings are slightly wider than the OEM moldings and the clips will fall out without the shim.
The only clip needed but not in this set are the ones with the studs welded onto them that go at the top of the door outer edge...these are easy to make at home.
Price is $20 with free shipping to the lower 48 States.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
