| | | Forums66 Topics128,128 Posts1,056,668 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 122 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 122 | 1947 3100 steering wheel question. I am having trouble with the horn contact spring/pin on my truck. I have a new contact spring/pin but it seems like the hole in the steering wheel is bigger than it should be and the pin does not make contact for the horn and then disengage when released. It actually slips down in the hole and gets hung up. Not sure if the steering wheel spring hole needs an insert/sleeve or can be repaired by a machinist. Thanks! | | | | | Joined: Sep 2009 Posts: 5,975 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,975 | A couple pictures to show what you’re describing would help folks understand better what you have. That would improve the possible success of solutions that can be suggested.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
