1 members (Samantha), 45 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
#1606116 06/19/2026 4:24 PM
I got the 250 reassembled with some new parts and a used manifold set. And got it running!! 😎. Still lots to do.
Latest problem is a leaking original gas tank. 😥. I’m going to try and fix it with JBWeld. I patched an outboard motor tank with JBW decades ago. We’ll see.
Professional Novice
Ouch - That's a lot of pinhole leaks! big_eek
You can get a pretty inexpensive replacement tank off ebay with only about a $16 shipping charge. Significant discount from Jegs regular web site price.
If you have that kind of a current leakage issue, no telling how long before additional areas are going to give up the ghost and start leaking too. cry
~ Dan
1951 Chevy 3 window 3100
Thanks Gdads51
Professional Novice
JB Weld doesn't hold up to Dethanol fuel, ask me how I know..
Suggest cleaning out the inside of the tank with old gravel, then after it's clean and dry, use a quart of this stuff.. https://www.damonq.com/products/red-kote it's not cheap, but your tank will never leak again. After applying this stuff, you could slap some JB Weld on the outside if you still think it needs shoring up, as the internal coating will keep fuel from ever touching the JB Weld epoxy.
These days however, a new tank is just cheap insurance. You could even buy a new tank that relocates the flammable liquid storage outside the actual passenger compartment.
The last new tank I bought, I coated with red-kote before there was ever fuel in it. That way no one will ever have a problem with that tank, even if the fuel inside goes rotten, it won't rust the metal.
Thank you.
Professional Novice
I bought a new tank from Jegs for a reasonable price and have it installed. ✔️
Four new tires mounted and overhauling the brakes now. Hopefully have it on the road soon.
Professional Novice
Glad to hear you're making progress. Can you supplement some with a few pictures?
Would love to see what you've got going on. smile
~ Dan
Pictures of tires and wheels. Yes, I demounted the old tires and mounted the new ones myself with a Harbor Freight manual tire changer.
Not many other pictures of completed tasks.
Currently replacing the carrier bearing in the drive shaft and scrapping together an exhaust.
Professional Novice
