| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 253 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 253 | My 235, 1955 engine has solid lifters and they and don’t have a hole on the side like those advertised, why? Can install those new ones that have the hole on the side of lifter body?
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | If you think you'd be more comfortable with a hole- - - - -drill one. The lifter won't care. Just put it near the bottom so oil can't be trapped in the hollow lifter body. That's the reason for the hole in the lifters you're seeing in the ads. If you're installing a new cam and lifters, don't trash the old parts. Both the cam and lifters can be reconditioned. Jerry
| | | | | Joined: Mar 2021 Posts: 253 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 253 | I’m not contemplating adding a hole to my solid lifters. I’m concerned that if all of my lifters do not pass dimensional verification would be ok to install those sold by lets say Summit. Looks like my type lifters aren’t available. Furthermore, would it be ok to mix my type lifters with those that have that hole? Anyway what’s the reason for the hole?
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Like I already said- - - -the hole is to prevent oil from getting trapped inside the hollow body of the lifter. What brand of camshaft are you installing? Jerry
| | | | | Joined: Mar 2021 Posts: 253 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 253 | Well. At this point I’m only planning to use camshaft that’s presently in the engine, which I’ve not removed yet. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Be sure to do a very thorough check on the condition of the cam lobes with a degree wheel and a dial indicator- - - - -if the lifters are showing any measurable amount of wear, the cam lobes will be worn also. Schneider Cams in San Diego regrinds stovebolt cams, but a Melling CCS-1 cam is a really good option if you decide to go with a new cam. It's slightly better than the 261 engine cam that was also used in the 6 cylinder Corvette, without a creating a lumpy idle and bad intake manifold vacuum. Jerry
| | | | | Joined: Mar 2021 Posts: 253 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 253 | | | | | | Joined: Jun 2018 Posts: 94 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 94 | Have been where you're at. Put a stright edge across the lifter to cam surface on the lifter, If concave, like mine, you'll be headed in a differnt direction. If convex, things may be OK. Hope it works out!
1954 3600 Stakebed non-original engine out of a '55 passenger car with powerglide
