7 members (fonz8261, Shaffer's1950, tclederman, Hotrod Lincoln, Bill Hanlon, Charles in CA, 49choptop), 74 guests, and 3 robots.
Topics128,087
Posts1,056,376
Members48,442
I am looking for parking lamp assembly for a 1951 GMC. I have 1947 to 1950 assembly to trade if you need them.
warlock - Just to confirm, your looking for the 1951-53 3" diameter parking lamp assembly referred to in this Jim Carter 1947-1953 GMC Parklights Tech Article, yes?
~ Dan
1951 Chevy 3 window 3100
Just in case it may interest you, a quick web search located what is listed as NOS Guide GM Clear Glass Parking Light Assembly 1951-1953 GMC Pickup Trucks. Pricey, but considering there not growing or falling out of trees anywhere (no repops except for LED's which look horrible), maybe what you want.
I did try a search for "used", but go zero hits unfortunately. Hopefully there is a 'Bolter that can you help you out if this NOS one doesn't work out.
Best of luck in your search! thumbs_up
~ Dan
Yes that's what I need but I need 2 of them...I saw the one on ebay but am hoping to find both at once. Thanks though
Haunting the SBP since 2001
Not sure what your budget is but, I have a pair that are NOS.
Never installed....one is still in the original tattered GM box... new 12 volt bulbs....working & ready to mount.
PM me for more info.
