2 members (Tronman, 50wudy), 168 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
#1611470 09/16/2026 6:16 PM
Moderated
Moderated
I am a new big bolt owner and new to the forum. I have a 2 ton 6400 that I need to rebuild the steering on. I am having a hard time finding the center link tie rod, does anyone have a source for these? I saw the upgraded HD rods on some of the websites but they are for 1/2-3/4 ton models.
1951 2 Ton 6400 stake side
1953 3/4 Ton rolling chassis, needs a heart.
1976 Caprice, rusting into oblivion
Jman #1611502 09/17/2026 12:46 AM
Jman - Welcome to Stovebolt! wave
Going to presume your "6400" is an AD Series truck, but it would help to know the specific year as it sometimes can make a difference on parts. A quick check of a 1929-57 Chevy Master Parts Book shows the tie rod ends for your 6400 should be:
Left - GM# 609747 (Modern replacements listed as ES142L amongst other part numbers)
Right - GM# 609748 (Modern replacements listed as ES142R amongst other part numbers)
A quick web search shows many NOS Left and Right Tie Rod End assemblies available at various price points. Here's just 2 reasonably priced NOS units that I found being advertised on eBay:
NOS GM# 609747
NOS GM# 609748
If you'd rather pursue newer replacements, here are a couple from the same supplier:
Tie Rod End 462.ES142L
Tie Rod End 462.ES142R
The new replacements are more expensive, but haven't sat on a shelf for decades and have the rubber boots that are almost always missing from the NOS GM pieces.
~ Dan
1951 Chevy 3 window 3100
Jman #1611516 09/17/2026 10:54 AM
7
7 Offline
Welcome Jman, if I understand your question correctly, you are looking for the main section of the tie rod, we can also assume you would need the tie rod ends. Certainly the info for your particular truck will help us to help you when searching for parts. Gdads51 probably can give you a part number for the tie rod and that should be useful in locating an aftermarket or original part.
Jman #1611527 09/17/2026 2:52 PM
Buckshot - Thanks for catching what I clearly missed in my first response - not me
Jman - Here's more info on the center "tie rod" (not including the tie rod ends) and the "clamps" that are needed with appropriate bolts and nuts to secure the tie rod ends to the center tie rod bar.
Chevy Parts Group 6.230 - Rod, Front Axle Tie GM# 3683223 47-1/2" overall length, 1" - 16 thds Right Hand and Left Hand (female ends) *
* Also listed in GMC Master Parts Books as Group 1.0400
Chevy Parts Group 6.234 - Clamp, Tie Rod End GM# 3681858 (requires 2 each)** / ***
** The Chevy Master Parts Books do not list the bolt and nut info that are needed for the clamps, nor does an early 1950 GMC Master Parts Books list them.
*** A later GMC Master Parts Book list the hardware as Bolt - 7/16 - 20 X 2 with a corresponding 7/16 - 20 nut.
You can see the Chevy and GMC truck models/years that these pieces were used on in the screenshots below. Added in case you need to seek a donor truck for the parts.
I did do a quick web search and found nothing being offered for the main tie rod, but did find One NOS GM# 3681858 Clamp being offered.
Hope this helps you get what you need for rebuilding your 6400 steering. wink
~ Dan
Jman #1611530 09/17/2026 3:04 PM
Jman - One more potential find for you on tie rod ends. Here's an NORS ES142 Set of tie rod ends that will fit your truck for a very reasonable asking price if that's what you need. wink
Come back and let us know how things turn out. thumbs_up
~ Dan
Jman #1611568 09/17/2026 11:00 PM
7
7 Offline
Hope it helps. I've been told I'm smart, if I was also handsome, I'd be perfect!
Jman #1612824 10/08/2026 1:49 AM
Moderated
Moderated
Guys, thank you so much for the information. I did not have alerts setup for posts, so I’m sorry for ghosting you for so long.
It is a 1951. I purchased it from a rat rod builder, so it is complete except for the front axle and steering wheel which is what he wanted for his project.
I found a complete axle with steering column at a salvage yard. The downside is it was half way below the ground level for many decades, probably a poor choice on my part but that’s another story.
I was able to find a NOS new axle, but looking for steering parts to be able to drive it around the farm.
Thanks again for the information!
Jman #1612827 10/08/2026 2:35 AM
Moderated
Moderated
Here are a few shots to lay eyes
Jman #1612859 10/08/2026 8:32 PM
Crusty Old Sarge
Crusty Old Sarge
That axel is going to need a lot of love to get it cleaned up. Finding a better candidate might be easier.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Jman #1612889 10/09/2026 1:56 AM
Moderated
Moderated
I took off all the steering arms and am trying to get the drums off. The pads are bonded to the drumps, I think I may have bent the brake hanger backing plate. Suggestions on getting a heavily corroded drum off the pads?
Jman #1612908 10/09/2026 12:14 PM
I doubt that the drums can be used so just cut them may be your best option.
1949/50 3600 Project
Follow in Project Journals
Jman #1613129 10/12/2026 6:18 PM
Quit while you're ahead...find a better donor as there won't be any useable parts inside those drums.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Jman #1613153 10/12/2026 9:46 PM
That's not a NOS axle. It's a ROU (RUSTY OLD USED) axle. I agree with Craig (Tuts59), you'd be better off with a different axle. I doubt you'll find many usable parts on that one. Even the axle itself might be toast if you can even get the king pins out of it.
Jman #1613261 10/14/2026 1:02 PM
Crusty Old Sarge
Crusty Old Sarge
I would be willing to bet that KCMongo (Steve) would have a usable donor axle available. Mongo is in KC..
Drop him a PM, he usually responds pretty quick.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
