Brrrr
place holder
9 members (Otto Skorzeny, DennisM, G508, klhansen, Peggy M, dt235sd, 50Chevy3100, Hush, 1 invisible), 262 guests, and 7 robots.
Topics128,270
Posts1,058,408
Members48,485
My '46 Express with 9' bed had the running boards cut off at the rear and someone cobbled together some squarish sheet metal crap as rear fenders. I eventually found a correct pair of rear fenders but don't know how to fix the missing part of the running boards. Does anyone know if 1/2 or 3/4 ton running boards used the same profile at the rear where it meets/joins the front of the rear fender? Do you think if I found a pair of lighter truck boards I could cut off the back end and weld them to what's left of mine? I've only ever seen 1 pair of 1 ton boards advertised the past 15 years but the guy in Regina SK couldn't figure how to ship them to Michigan so I suspect they got cut down for a smaller truck. (Unless someone else on here has a pair?) Thanks
You might find the information and pictures in this same topic thread from the AACA Forums may be of some help.
I haven't had a chance to check the Master Parts Books for measurements/dimensions, but will post them if I can find them in the hopes it will help answer your question.
~ Dan
1951 Chevy 3 window 3100
Moderated by  Dusty53
