0 members (),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 18 | I'm looking for front and rear brake drums for my 1946 ¾-ton pickup. 8-lug pattern Searched some of the main suppliers and came up with zilch. Plenty of stock for 6-lug ½ ton but nothing for 8-lug ¾ ton. Any ideas on suppliers, or should I consider a disc conversion at this point? This truck doesn't get driven much, so if possible, I'd rather stick with the drums for now.
1946 Chevy 3600 Pickup 1948 Chevy Sport Coupe Country Club 1963 Corvair Monza Spyder Convertible
| | | | | Joined: Oct 2021 Posts: 6,885 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,885 | Call these people. Specializing in antique, vintage, classic, obsolete, unique and hard-to-find brake parts, bonding, riveting, rebuilding, drum and rotor machining, custom made brake hoses Brake Materials & Parts Inc 800 Sherman Boulevard, Fort Wayne, IN 46808 260-426-3331 http://www.brakematerialsandparts.webs.com/
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2015 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 18 | Otto Skorzeny, thanks for the lead to Brake Materials & Parts. Unfortunately, they don't have anything that would work for me. He said that he's had calls about these for the past 10 years or more and has never seen them. Seems like I'm chasing a unicorn.
| | | | | Joined: Oct 2021 Posts: 6,885 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,885 | Rats! I thought for sure he'd be able to help you.
What about having them reline the shoes to double thickness in order to work with the old drums? Not ideal but for a lightly used truck I think they'd be fine.
| | | | | Joined: Sep 2019 Posts: 162 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 162 | What about having them reline the shoes to double thickness in order to work with the old drums? Not ideal but for a lightly used truck I think they'd be fine. Now that’s using your head for more than a hat rack. Clever means to an end.
I invest my money in precious metals, mostly rust!
| | | | | Joined: May 2015 Posts: 11,105 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,105 | Most brake drums have a maximum diameter number cast into them to know when it's time to quit turning them. As the drums get turned, they get thinner and will heat up quicker and may actually separate into a disc and a band stuck to the shoes. One way to reuse worn brake drums is to get the inner surface rebuilt with a metal spray process, but that's big bucks if you can find someone to do it.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2009 Posts: 5,964 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,964 | eclector - You probably already know that the front drums GM# 609779 for your 3/4 ton are listed in the Master Parts Books as a 1 year only. The rear drums are listed as GM# 609807 and were shown fitting 1946-52 3/4 tons. Both have achieved "unobtanium" status as far as I can tell searching through the web. The only listing I found was for the rear drums at Jim Carter under MEB126, but they have been out of stock for a long time and unlikely to come back in stock. Absolutely no front drums listed anywhere, not even used stuff.  About the only thing I can offer is to suggest you search your local FBM and Craigslist ads for someone selling off axle assemblies or parting trucks that might still have something useful on them. Other than that, reach out to fellow 'Bolter KCMongo as he might have something used still on hand. NOTE: I've moved your post to the best forum to continue the parts hunt conversation.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2009 Posts: 5,964 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,964 | On a follow up note, if you want to discuss upgrading/modifying your existing brakes to replace what can't be found, please start a new thread in the Driveline forum to further discuss those options.
| | | | | Joined: Sep 2009 Posts: 5,964 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,964 | Just a follow-up note that I had lunch with Steve "KCMongo" yesterday and he said he probably does have some usable drums, needing turning as all his stuff is coming off of trucks being salvaged. Please give him a call if you are interested in moving further on this.
