5 members (Philipj, Peggy M, Wayne67vert, Biermann, Phak1), 69 guests, and 3 robots.
Topics128,153
Posts1,056,849
Members48,456
Page 15 of 16 1 2 … 13 14 15 16
"The Little Blue Truck" is certainly earning it's keep. thumbs_up
Thanks for posting Wayne! grin
~ Dan
1951 Chevy 3 window 3100
U
U Offline
Nice. What are the plywood cutouts on the sides?
~ John in Utah
Here We Go
Follow in his DITY Bay
back yard wrench turner
W Online: Content
The cut outs are of Mr. Toad who is a friend of The Little Blue Truck and gets to drive the truck in the books.
Mr Toad
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Crusty Old Sarge
Crusty Old Sarge
Little Blue is probably having flashbacks of being a Farm Truck... grin
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
I'm not sure this entry qualifies, but my truck was used. This picture is from my granddaughter's wedding in 2019.
Bill - Chalk that up as being "fully qualified". Thanks for sharing. thumbs_up
~ Dan
This picture has more of a truck oriented story.
The little girl, about 3 years old when we first met, across the road from us is turning into a 24 year old bride. Two days before the wedding she sends me a text asking if she and her guy can use my ’52 GMC ¾ ton flatbed for their “getaway car”. I told her I would be honored
Early the next morning I gave it a good washing and cleaned up the inside. That afternoon my wife followed me to the wedding venue, about 5 miles north of town. I met up with the bride’s father to give him the key (groom was busy) and a quick lesson in stomp starters.
Started the engine once. The second time I stomped the starter the engine started, but the was a really bad noise coming from under the hood. Turned off the key and tried again. Same result. Aaaaaaaaaaaaaaaaaaaaaaaargh!!
The 74 year old “starting motor control return spring” picked today to break, so the starter stayed engaged when I took my foot off of the stomper. Engine was running and the still engaged starter motor was spinning a lot faster than it was designed for.
I went home and looked through my meager collection of springs. There were 3 that might do, but none real close. Pondered that for a minute and then the answer came to me. ‘Bolter GiantMountainClimber (Kenneth Crenwelge) has a slew of old GMC trucks sitting at his business. His place was between me and the wedding venue. Kenneth answered on the first ring and after my desperate explanation said he’d meet me there shortly. We liberated a spring from one of his trucks and I was on my way. Big thanks again Kenneth!
Meanwhile, back at the truck…. While changing the spring I could hear the radio playing. What? I had pulled the key from the ignition switch and given it to the bride’s father when the spring failed 3+ hours before. Finished installing the spring. Got into the truck and realized I had removed the key with the ignition switch on. Oh well. Stuck my spare key in and stomped the starter. Nothing! Nada! Kaput!
Truck had been converted to 12 volts when I bought it in 2013. My voltmeter (I have an aftermarket instrument panel) read less than 8 volts, the lowest mark on the scale. Tried again with the same results. My world had just become a $#!+ sandwich and I was the bottom slice of bread.
Turned off the key and drug the jumper cables from under the seat. Nudged my wife’s Camry near the truck and attached the jumpers. Cranked up the Camry and jammed a water bottle beside the gas pedal to hold the throttle at about 2300 RPM. Let it charge for 15 minutes. Hit the stomper and the engine reluctantly came to life. Pulled the jumpers off and let the truck run at high idle for 10 minutes. Turned off the truck. Turned the key back on. NO VOLTS!
The 2 year old battery had died when the ignition was left on for a couple of hours. I called my local O’Reilly’s where I bought the battery. Explained what happened. The counterman asked for my phone number and looked up the battery. He said he had one in stock and that mine was still under warrantee. “Bring it in and I’ll replace it”.
Walked into Oreilly’s 15 minutes later. My new battery was sitting on the counter. The guy gave me a receipt with a zero balance and 15 minutes later I was installing the battery.
Started right up!
Truck performed well as the "getaway car".
Bill, that's one heck of a story. Glad you got things straightened out eventually.
I may steal that sandwich comment from you. Sounds about right for some events. dang
Authorized Pest
Authorized Pest
P Online: Content
Indeed one heck of a story. I was getting a tummy ache after the first few paragraphs. Goodness, how many things could go wrong? What a stress monster.
Thanks for the story. Good retelling.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
AD Addict & Tinkerer
Fitting for that old saying, “When it rains, it pours.” Man, I’ve been there too many times! Just when you really need something to go right, Murphy’s Law comes into full effect and tests every ounce of your patience.
I know how stressful moments like that can be in the thick of it, but I am so glad it all worked out in the end. Looking back, the hiccup will just be part of the story—and at the end of the day, the new couple still has a memory that will last a lifetime!
Take a deep breath and pat yourself on the back.
Phil
Project Journals
What a sequence of problems arising from a simple spring.
About the only thing that could make the stress level any higher would be if it was your daughters/sons wedding event!
Glad to hear it all worked out in the end.
1949/50 3600 Project
Follow in Project Journals
Crusty Old Sarge
Crusty Old Sarge
Bill, you came through like a Trooper! No doubt the Bride and Groom will have a stories to tell from their Wedding Day... and so will you...
Mission Accomplished... thumbs_up
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Ol' Roy had to go to the auto parts store today on behalf of his stable mate, Little Red.
Yeah, guess why? The new Chinese fuel pump packed it in. Par for the course these days.
1950 Chevrolet 3100 (Ol' Roy)
U
U Offline
Finally get to add a photo of my "Working Truck". I drove south a little bit to a friend's small farm in Payson, Utah. She gave me a great deal on some sweet corn, so I shared it with the neighbors on my culdesac. Good tasting corn! Watermelon and cantaloupe will be ready after Labor Day.
~ John in Utah
Here We Go
That's awesome. I wish I lived near you so I could get some fresh corn!
Yes, need to be closer neighbors! grin Perfect pictures for this thread! thumbs_up Thanks for posting them John! shake
~ Dan
Had to haul a lawn mower to the repair place where I promptly ran out of gas.
Fortunately lawn mower man gave me some and got that taken care of. I really need to fix or replace that sending unit. And then as it turned out I didn't need to buy a new recoil spring assembly for the mower.s I remembered that I have a spare parts mower with the same oddball part.
At least the lawn mower place was close to the farmers market. I needed to go and get some non-diarrhea-inducing lettuce and some other stuff.
A productive morning, indeed!
Otto ,
That starboard side running board sure looks good. Usually pretty banged up.
Yeah, both running boards are perfectly straight with little or no damage. In fact the only real damage is the passenger rear fender which is recent.
Somebody in a welding truck or similar vehicle with a high metal flat bed gouged and creased it fender and opened it up like the Titanic.
Even though this truck worked on a farm in Tennessee into the late '80s and early 90s, it at least got to stay inside a barn or garage of some type so there isn't even any rust in the cab corners.
Both front fenders have been replaced at some point however as the driver side one appears to have originally been that light green color, mint. And the passenger side fender appears to have originally been light blue.
The truck itself was originally Mariner blue
What are you planning to do about the fender that hit the iceberg?
Funny you mention that. Just last weekend a friend of mine was over and I was showing it to him and he said take it off and he would fix it and try and weld up that slit. So that'll be the game plan. Although I hate to bother him with it because he's got his own multi car projects going on the same as me.
Yeah while I was underneath it a week or so ago cleaning off the oil and grime underneath, I noticed that one of the struts for the fender broke off where it bolts to the frame.
I think the end with the i in it for the bolt can be welded back into place so I'll try to do that as well and then of course the the bracket or strut that's up at the top of the fender right where the gash is is also banged up under there so once I get it off I'll know more.
Getting the gash welded sounds good. Then you have decide whether to fair it out or leave it as a battle scar …?
We'll do the best we can to get it smoothed out and back into original contour. It will only be primed, though . Doing all the bodywork on this truck to do a proper paint job would cost more than you could even sell the truck for when it was finished.
Overall it's straight with no rust but every panel has dents/ The bed rails and bed front are rusted. The hood was used as a ladder to access a pull down attic stair so its current beat up appearance is more or less permanent.
I use my 53 3100 as a truck. Sometimes it makes me slightly sad or nervous when I put something in the bed that I know will at least blemish it slightly, or maybe worse. But that feeling is offset by people telling me how cool it is that I'm still using it. All in all it's just fun. Mine is definately not a show truck. I never set out to create a show truck. I only wanted a reliable driver that was "respectable". So far it seems like that's what ive got. I did every bit of the work myself, so I figure that I saved a good bit of money along the way. I doubt that I'll ever sell it anyway. Maybe I'll just use it for a casket.LOL
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Heck ya! It's a truck, drive it! What are you going to do, park it in the garage and save it until you're dead so somebody else can enjoy it? The heck with that. There's no such thing as a car that's too nice to drive every day.
There's a guy in metro Atlanta (Peachtree City area) that owns a J model Duesenberg. He drives it to work most of the time.
Mike, I could not have said it better for my ‘57 3200. I’ve had it for 11 years and enjoy every minute I take it out. Usually hauling something for family or home from a big box store. Finally finishing the paint job I started 2 years ago! Hopefully anyway. It will be totally dark brown with everything else gloss black. Possibly a stripe down the hood in flat black to reduce any clear coat glare everywhere else.
CHATGPT (AI) generated the attached picture as an example starting from pic of my truck.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
I don’t do any real hauling with my ‘54 , only toys.
That said, I’m in my 4th summer with it and the odometer just clicked 5800. That’s got to count for something.
What really counts is an odometer that works! smile
1957 Chevy 3200
Daily Driver
Follow in the DITY
My odometer does indeed work.
Easy to figure out how many mikes I’ve driven since the build because I started from zero.
My odometer is the same, started at "0" after my build because I changed the cluster and chose to start at "0" rather than input the previous miles.
Donald S.
Donald S.
I did the same thing also.
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
U
U Offline
Made a second farm trip to get some Sweet Corn for the cudelsac. I added some juicy cantaloupe as well. This time I took the old truck down the back roads from Provo to Payson, UT. It was about 36 miles round trip. No issues.
~ John in Utah
Here We Go
Authorized Pest
Authorized Pest
P Online: Content
John, that's one of my favorite pictures -- seeing an old truck with produce in the back. smile
~ Peggy M
1949 Chevrolet 3804
24601
24601
Ole CHarlie is currently awaiting an exhaust system repair ... (blew the donut out between the manifold and the exhaust pipe ...) returning from the Guntersville show frown So I worked the Cornbolt this week. Charlie isn't set up to move 6 rolls anyway ... An old truck is an old truck and as you all well know, we have a couple of non-Stovebolts kicking around HQ ...
Here's Hobbes, the '73 Cornbolt 1-ton earning his keep yesterday moving the second cutting of hay.
Hobbes haulin' hay.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Well, Old Roy finally got put back into service. And back in the rotation. Drove to the farmers market today to pick some stuff up and the engine ran like a Swiss watch. (A noisy one)
Much quieter on the freeway at 60 MPH with no issues.
U
U Offline
Nice. I've not been on the freeway - YET! I've gone 55 though.
~ John in Utah
Here We Go
I'd be worried about a little under 15 psi of oil pressure at 60 mph, but I'm driving a GMC.
I'm not worried about it.
That's dead on factory spec.
The service manual calls for. 15 psi while driving , 8 PSI while idling.
The only time it's higher than that is at cold startup. It'll sometimes go to 20 or 25 and then once it warms up it's back down to 15.
And since this engine hasn't been in rebuilt to my knowledge I figure that's pretty good for a 75-year-old engine. It could have been done sometime in the 70s or '80s I suppose. But I know the history of it back to a little over 25 years and it hasn't had any work done to it in that time
Crusty Old Sarge
Crusty Old Sarge
Thor is back at. This thing rides so much better with a load. grin
$500.00 sure doesn't buy what it used to.
Back home safe and sound, I really like having the extra stopping power with the Disc Brakes. I had to test the stopping distance once on the way home, car decided they needed my lane to make an immediate right hand turn...
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
