4 members (Nick in Manitou, Hotrod Lincoln, TUTS 59, 46 Texaco), 146 guests, and 1 robot.
Topics128,119
Posts1,056,313
Members48,439
#1610293 08/28/2026 10:47 AM
Hi all,
I’m potentially picking up a GMC engine in the near future and will need a way to store it and move it around as needed. Deve’s Technical Network has plans for an engine stand that looks easy to build and more than strong enough to carry a Chevy 235. Has anyone built that stand and used it for a GMC engine? If not, has anyone been able to build their own engine stand for a GMC? The key dimension would be the width of the oil pan flange since that’s what the cart ultimately uses to rest the engine on.
'53 GMC 3100
"I think your obsession with auto shop stems from your unresolved feelings about your father"
-Bobby Hill
I've built 3 engine stands from the one in Tech Tips. Search Tech Tips on this site for, Build an Engine Dolly / Caddy. Very sturdy, easy to build. Without wheels they are very sturdy to set an engine on for transport.
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
AD Addict & Tinkerer
Here is a link to that TechTip.
Phil
Project Journals
Stovebolt Gallery Forum
Here's the link to the Legacy Tech Tip by 'Bolter "Farmdog" Build an Engine Dolly / Caddy that GMCJammer51 refers to. wink
I've built and currently use 2 of these stands/dolly's, one for a 235 and the other for a 261. Pictures below are the stand for the 261 when waiting for arrival and now pending transport next week to the overhaul shop.
I did a couple of minor mods to the plan in my most recent build, adding hard rubber padding and foil tape to retain across the tops of the uprights (to help prevent potential splitting/cracking of the uprights), mounted the casters just a tad wider apart than the original plans (to add stability) and bevel cut the outer upper corners of the 4x4 cross pieces (just because - lol).
I'll have to check the GMC to Chevy 6 width dimensions, but going by "GMCJammer51's" reply, feel pretty confident the design will support your GMC engine. wink
Edit Note: Phil beat me to the post button - lol! smile
~ Dan
1951 Chevy 3 window 3100
B Online: Content
I built this one from scrap lumber I had and a repurposed set of 4 dolly wheels. Pictures show a GMC 302 deep pan (uses the same pan gasket set as GMC 228, 236, 248, 256 & 270) on the stand.
The larger dolly wheels are both a blessing and a curse. They are good because they roll easier and they are bad because they roll easier when you don't want them to.
I can get you critical measurements if you decide to build your own this way.
This looks a lot cheaper than the cart I saw elsewhere. I might start building this this weekend. Thanks all!
'53 GMC 3100
-Bobby Hill
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
I have several engines on these rolling stands. They hold up pretty well. I made one just a little wider for use with my V8's( has a 283 on it now). You just want to use some quality casters, 2 of mine are locking type..
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
A good starting point for a wood engine stand would be a Harbor Freight furniture dolly. I used the casters from one of them but built mine out of some scrap square steel tubing I had laying around.
HERE'S MY ENGINE STAND - IT'S RESTING RIGHT NOW
I made this one from the bottom part I bought at an engine builders auction (Gearte Racing Engines) for $40. I made the top from an old cherry picker and the the outriggers from stock from McMaster Carr. There will be a 6-71 hanging off the hot chick side of the engine so I added the outriggers for stability. they retract. I will probably make this into a run stand.
I finished this guy last night. Initially I bought caster wheels from Lowe’s before discovering that I could buy 4 casters from HFT for the price of 1 Lowe’s caster. The rubber pads on top of the boards are HFT “anti-slip” mat and I also added some eyebolts to the sides so that I can put straps over the engine.
'53 GMC 3100
-Bobby Hill
Looks great! thumbs_up
~ Dan
@Mick53
HOW TALL ARE YOU?!! wink
Wouldn't it be better for the stand to be a bit shorter?
Originally Posted by klhansen
@Mick53
I'm 5' 10". I think it's a great working height. The bottom of the stand is a dyno run stand with super nice casters. I'm kind of locked in on that. It's very stable. I am concerned with the 100 pound blower hanging of the passenger side of the head so I put the retractable outriggers on it. I can pull the trans and mount and still maybe hook the stand to a dyno. The hardware is still there. I don't know how that works. The top of the engine is a nice bar stool height and the bottom is a shop stool height. It works for me.
Mick, OK, whatever works for you. Nice looking construction, BTW. thumbs_up
I will admit that mine doesn't work well for installing the flywheel, clutch or transmission, so I do that with the engine hanging from the engine hoist. It just seemed a bit tall in your first pictures.
With the dry sump I do a lot of work on the bottom half of the engine and crankshaft. That is one of the reasons it's taller than it needs to be. I also wanted to be able to remove the oil pan on the stand.
This is what works for me to store GMC engines and roll around as needed. 2- 2x12x27” for lengthwise 2- 2x6x22” for cross ways or the stability legs. Space the 27” about 9” apart screw the 2x6s using 3” deckmate or equivalent screws (not drywall screws) 2 or 3 per corner. Sit the new box in the floor or sit it in a moving dolly. Load the engine in it. I use a ratchet strap if I’m rolling it around but they stay in there pretty good. I’ll try to post measurements and photos. Total cost $20-30. Jim D
pictures below
https://picasaweb.google.com/111413431667404132006
Jim D - '48 GMC 1ton pickup
Measurements. It’s showing 30” BUT Don’t forget to subtract 3” for the width of the 2-2x6s which makes them 27” in length
pictures below
This on has plywood up taller above the 2x6 legs for added stability
pictures below
Sorry haven't posted for a while and not too good at posting photos didn't know about the pixel limit.
All of these stands can sit on the floor. I have them sitting on $15. Harbor Freight moving dollies, they easily support the engine weight. The depth, width, and length of the oil pan determines the frame. The depth is the only variable deep pan vs shallow. I hope this photo posts correctly
pictures below
NOTAS (Notice to All Stovebolters)
If you’re using the Harbor Freight 1 ton engine hoist to remove your engine, the wooden cart design on this website will need modification! My friend and I had to do…a sketchy maneuver to put my GMC 248 into my rolling engine cradle this past weekend. The cart is too wide to fit between the legs of the Harbor Freight engine hoist and the little nubs of 4x4 that stick out past the uprights will have to be modified.
Addendum:
If you have the money for the 2 ton engine hoist at HFT, I recommend you buy one of those as the 1 ton hoist has too short of an arm for a standard truck bed. Myself and ‘49nut’ had to get creative loading my engine into the back of my Maverick.
'53 GMC 3100
-Bobby Hill
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
That Jimmy weighs more than your Maverick...
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
