8 members (Hotrod Lincoln, MickeyP, Peggy M, 55shaker, klhansen, Craig /49 Panel, Shaffer's1950, Otto Skorzeny), 69 guests, and 1 robot.
Topics128,132
Posts1,056,386
Members48,441
Crusty Old Sarge
Crusty Old Sarge
I'm trying to locate tires for my '51 GMC 250. The radial equivalent is a 215/85r/18, 18" load rated tires are pretty scarce. The Truck has currently has split rims, pretty sure they are not the "Widow Makers". I'm not a stranger to split rims and have no issue doing the mounting myself ( Army Trainining Sir salute2). I can get radial tubes thur NAPA.
I looking for something that looks period correct and load rated D - F.
Any ideas ??
7.00-18
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Moderator
Moderator
2 Offline
Let me know what you find Craig. I have a 57 with the split rims also that need 18’s.
From what I know, be prepared to work some overtime to pay for them.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
RLB Offline
Hey Craig. I gave your tire size to a friend that just retired from a tire manufacturer who had bought up a bunch of the old tire companies names & molds. He's going to see what he can find.
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
All "split rim" wheels can be dangerous but the true "widow maker" was the Firestone RH5 two piece wheel.
BC
1960 C60 pasture art
Crusty Old Sarge
Crusty Old Sarge
So far the only option I can find is a 7.00- 18 Coker Tire, it's $390.00 load range D.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
O Online: Content
I would not buy Coker tires. They're for show, not driving. They're made on 80 year old, worn out molds and and are hard or impossible to balance properly.
Even Corky Coker suggested to the president of the Peach State region of the CLC that if you're building a show car, buy Cokers. If you drive your car, buy Diamondbacks.
Diamondback makes a 700x18 blackwall radial for $349. It's expensive but it will be superior to anything Coker makes.
Auburn Deluxe Radial https://dbtires.com/product/auburn-deluxe-radial-15-16-sizes/?style=blackwall
32.5 dia
5.5 tread width
7.5 section width
1929 lbs load capacity
1950 Chevrolet 3100 (Ol' Roy)
Crusty Old Sarge
Crusty Old Sarge
I'm looking for a tire with a higher load rating. I would prefer at least a D, but an E would be better. There are plenty of 18 inch tire available just not in a width narrow enough for these old wheels.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Crusty Old Sarge
Crusty Old Sarge
I found these for steer tires. Still haven't located an affordable traction style tire for the rear.
https://otrusa.com/products/7-00-18...zBm9y54_GlWtJUolE7VfGycILHRoC7L4QAvD_BwE
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
24601
Craig -- Are you doing serious work with Thor that you actually need traction tires back there? If all you are doing, really, is playing with the truck, then steers on the rear may be a viable last-resort option.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Crusty Old Sarge
Crusty Old Sarge
John, these are for the '51 GMC 250. I have 19.5" wheels and tires on Thor (4400 1.5 ton). Thor gets worked a lot. The tires currently the GMC probably date to the 60's or older. I have less than $800.00 in the new tires and 19.5 wheels on Thor.
1951 GMC 250
1958 Chevrolet 4400 (Thor)
19.5 tires and wheels
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
24601
Roger that. As I was, then.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Crusty Old Sarge
Crusty Old Sarge
If it weren't for the look of the wheels I would be fine with swapping them out for something newer and more common. I just really like the the "Old School " look of the dually wheels, to me they make the Truck.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Crusty Old Sarge
Crusty Old Sarge
Just a quick update. While I haven't pulled the trigger and purchased any tires as yet my research led me to this tire. It's a Kenda Klever H/T 4S, this size is a 235/80R18, which will accomadate a 6 inch rim width. The tire is 10 ply and load rated E at 3297/2910 lbs. single to dual mounting. While a radial tube may be required for my use it should suit a standard drop center rim just fine.
https://www.tiremart.com/shop?sizeAll=235%2F80R18
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
O Online: Content
Otto - Thanks for offering the direct link to Craig selected tire.
Craig - That looks like it's going to check all your boxes to upgrade your 250's tires. thumbs_up Kinda figuring your unlikely to push that new tire speed rating (106mph) envelop - hahaha! drive But nice to know they are capable. wink
~ Dan
1951 Chevy 3 window 3100
