2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
AD Addict & Tinkerer
After aligning the front clip on my AD truck there is a slight gap between the fender and the cowl. The gap is slight, but if I shine a light thru, I can see it, which will allow water splashed from the tire to get thru. What have others done to seal this gap?
Ad fender to cowl gap
Phil
Project Journals
Stovebolt Gallery Forum
Phil, you could put some webbing in the joint, or some fender bead to fill the gap. Fender bead wasn't used in the factory as as far as I know, however. These trucks weren't luxury vehicles and I don't believe the factory worried too much about fit.
My driver's side fender fit horribly when first installed. The very front of the cowl panel I welded in was too far outboard, so the last time I had the front clip off, I cut and rewelded the cowl to fix the fit. It was MUCH better after I did that. Link showing the repair.
If you are only worried about splash coming through from the underside could you put a bead of sealant on the inside? Personly I wouldn't worry about it but it's your truck and your decision about what you want to do.
1949/50 3600 Project
Follow in Project Journals
Ol' Roy's gaps are similar. Driver side has a a gap like your picture. Passenger side is a little tighter but there is a spot where you can see light shine through.
Did these two surfaces mate perfectly when new? Probably not.
1950 Chevrolet 3100 (Ol' Roy)
The factory beaded seal should cover that gap once you tighten the fender bolts.
GM chose that beaded fender welt to specifically hide gaps there.
