2 members (JW51, TUTS 59), 133 guests, and 4 robots.
Topics128,089
Posts1,056,362
Members48,442
The water pump is leaking, not surprised as it has been sitting for decades.
Are parts available? Or should I be searching for another pump?
I have a machine shop shop so rebuilding is an option.
Dave
Evilbay offered water pump rebuild kit (requires machine work on casting per details).
OR
Evilbay offered Reproduction NEW replacement for GM# 598309 water pump.
~ Dan
1951 Chevy 3 window 3100
This guy rebuilt mine. Excellent job.
Water pump rebuilder and seller of antique water pumps for all makes and models Services Europe and USA
Flying Dutchman
Wade Jenezon, 650 Upper River Rd
Gold Hill, OR 97525 USA
1-888-595-1110 Outside the U.S., 1-541-450-2277
http://water-pump-rebuilders.com/
This company also does rebuilding work and has a good reputation. They may also sell you a rebuild kit.
Then and Now Automotive
447 Washington St
Weymouth, Ma 02188
Ph: 781.335.8860
Fax: 781.335.1925
1950 Chevrolet 3100 (Ol' Roy)
Memphis equipment sells military surplus on eBay for $125. I have bought quite a few of them and they fit any 228,248,270 or 302. They just use different pulleys.
Dave
If parts are available and you have a good core I would just rebuild it. You clearly have the necessary tools and by extension the skills. It's not hard and can be done if you had to with a hammer and some blocks of wood. JMHO. I prefer to do things myself for peace of mind. Nobody cares as much about your part as you do. Thank you for your time.
