0 members (),
244
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2026 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2026 Posts: 70 | The water pump is leaking, not surprised as it has been sitting for decades. Are parts available? Or should I be searching for another pump? I have a machine shop shop so rebuilding is an option.
Dave | | | | | Joined: Sep 2009 Posts: 5,878 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,878 | Evilbay offered water pump rebuild kit (requires machine work on casting per details). OR Evilbay offered Reproduction NEW replacement for GM# 598309 water pump.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Oct 2021 Posts: 6,805 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,805 | This guy rebuilt mine. Excellent job. Water pump rebuilder and seller of antique water pumps for all makes and models Services Europe and USA Flying Dutchman Wade Jenezon, 650 Upper River Rd Gold Hill, OR 97525 USA 1-888-595-1110 Outside the U.S., 1-541-450-2277 http://water-pump-rebuilders.com/This company also does rebuilding work and has a good reputation. They may also sell you a rebuild kit. Then and Now Automotive 447 Washington St Weymouth, Ma 02188 Ph: 781.335.8860 Fax: 781.335.1925
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Memphis equipment sells military surplus on eBay for $125. I have bought quite a few of them and they fit any 228,248,270 or 302. They just use different pulleys. | | | | | Joined: Apr 2016 Posts: 1,045 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,045 | The water pump is leaking, not surprised as it has been sitting for decades. Are parts available? Or should I be searching for another pump? I have a machine shop shop so rebuilding is an option.
Dave If parts are available and you have a good core I would just rebuild it. You clearly have the necessary tools and by extension the skills. It's not hard and can be done if you had to with a hammer and some blocks of wood. JMHO. I prefer to do things myself for peace of mind. Nobody cares as much about your part as you do. Thank you for your time.
