0 members (), 347 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
Car shows, internet pictures of AD trucks mostly uses kits. I wanted to do something different. After much thinking, drawings and measurements, I came up with a plan. The bed is wider than 4ft. I split the plywood, laid out bed cross sills, laid the two pieces in, lined it up and marked bolt holes and bored them.
I used 2 4x8x3/4 Baltic birch plywood. Under side and edges were sealed with 3 coats of primer and 3 coats of rustoleum oil based paint in black gloss.
Next used dark mahogany stain. Next set up plywood on a level bench. Next was pouring 7 layers of west system clear epoxy. 400 grit sanding between layers and tack cloth. Note using epoxy must be poured in a controlled temperature environment. NEVER outside in the sun.
Then used aluminum flat bar and angle for the sides. Wet sanded with 400 to 1200 grit paper. On to polishing using a pneumatic angle grinder, wool polishing pad, and Flitz metal polish. Holes are bored and countersink for 1/4-20 taper head stainless bolts with nylock nuts.
I'm happy with it
What's the chrome circle on the bed?
1950 Chevrolet 3100 (Ol' Roy)
Gas filler
Very nice result!
Nick
1940 KC Model 1/2 Ton Pickup Project
(with '37-'39 Bed and what we think is a '42-'46 Frame)
Taos, New Mexico
Looks nice! A REAL GOOD one!
S2
Stewart2
1955.1 3100
Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC
Jack of several trades and experiences; Master of none
Nice looking, but how are you going to bring home a load of mulch?
Utility trailer or my 03 tundra - aka The Toad
Absolutely beautiful!
1952 5 window 3100
"Learning as I go"
Follow in the DITY
RLB Offline
Very nice. Definitely thinking outside the box!
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
Very nice job. I also did a similar to my truck many many years ago, using a full size ping pong table 5' x 9' x 3/4" plywood, way back when they were available. Cut it down just a little to fit the truck. Again, very nice job Canine Man. Enjoy the ride.
Craig
