3 members (Philipj, walter74, BillyDon), 65 guests, and 4 robots.
Topics128,180
Posts1,057,150
Members48,464
Hi all,
Jim Carter Truck Parts told me they couldn't paint my 1952 Chev temp gauge tan because the two are not interchangeable. I'd have to start with a 1952 GMC temp gauge. Can that be right?
Hilary Smith
PNW Sunny today
Hilary Smith
Hilary - Sounds like an odd response from them, but they don't usually do modifications to existing products that I'm aware of. They do offer a 1952-1953 Temperature Gauge as Original Chevrolet and GMC Pickup Truck that reportedly fits either truck. Yes, that one has a black face, but if you want the tan face, maybe just order their earlier 1947-51 "Tan" decal kit and overlay the black face with the "Tan" decal? If the new tan doesn't match your older tan, you could use the rest of the decals to reface all of them so they match. wink
With the new temp gauge, you will still need to get some red paint (probably a modeling paint would do) and repaint the needle to make it match your other gauges. That is if your existing gauges have the red needles?
A couple others factor to consider are what engine your truck has and if you've upgraded to 12 volt or not? You didn't mention either of those details, and I couldn't find anything in your previous posts to answer those questions. They can play a roll in deciding what gauge you order.
~ Dan
1951 Chevy 3 window 3100
B Online: Content
6 volts or 12 makes no difference with the Jim Carter gauge you pointed to Gdads.
Thanks for that detail Bill. wink
~ Dan
Many thanks for the responses. I found a source, LMC Truck, that had the GMC 47-51 temperature gauge in stock for $76 . . . but the shipping is $18.75. Still a steal I think.
Hilary Smith
