2 members (Patina 54, Chris's 46 / 515), 78 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
#1606975 07/02/2026 10:00 PM
I lost my old cap after setting it on the running board and driving off. Back tracking my path home yielded nothing. The cap is supposedly vented but when I remove it on a hot day, I get a substantial blast of gas fumes. Parts guy says the cap is only vented one way so as not to let fumes out but replacement air in only. He suggested I drill a small hole in the cap but I wonder about drilling a hole in what must be the check valve on the inside of the cap. What do you guys think?
I'm also going to epoxy some neodymium magnets to the cap so I can just stick it on the cab when I fill up so at least I won't lose it if I forget to put it back on.
1950 3600
1951 4400
Gazz
Gazz #1606977 07/02/2026 10:34 PM
I got mine from Napa it was in stock only a few bucks and is the proper vented cap .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Gazz #1606987 07/03/2026 1:00 AM
Nearly all the replacement caps today don't work properly.
The valve in the vent often sticks shut and doesn't allow fresh air into the tank to replace the volume of fuel removed by the fuel pump. This can damage the tank and the pump.
If your cap looks like this one, take a screwdriver and fold back those metal ears holding the plastic parts in place.
Take everything out and remove the plastic parts.
Behind the tan plastic part with the holes in it is a rubber valve and spring. Remove that valve and then put everything else back together.
1950 Chevrolet 3100 (Ol' Roy)
Gazz #1606995 07/03/2026 1:55 AM
If your cap has blue plastic on the underside, simply drill a 1/8" hole in the blue plastic just off the center of the round blue piece. Air will now be able to vent in and out as originally intended.
I have done this on four different trucks. Works like a champ.
Gazz #1607010 07/03/2026 3:26 AM
I bought the replacement from a local auto parts place but when I found out about the pressurized tank I called NAPA and they said they had the correct one. Turned out to be identical to the other replacement but in a NAPA box. In the morning I'm going to be working on it. Thanks for the replies!
1950 3600
1951 4400
Gazz
Gazz #1607464 07/09/2026 12:47 PM
I have a strict and simple procedure - when fueling my ‘54 I place the gas cap IN THE TRUCK BED , no exceptions.
(I once lost a really nice Leatherman by placing it on the bumper while changing hit balls. Hard lesson.)
Gazz #1607466 07/09/2026 1:07 PM
Yeah Wave, same here. I did the same thing with my Packard gas cap that had managed to survive almost 90 years without a scratch. I set it on the bumper and then heard it rattle off as I turned right onto the street. I immediately pulled over and ran back to get it just in time to see a car come by and run it over and completely destroy it.
Truck caps go in the bed, car caps go in my pocket.
Gazz #1607484 07/09/2026 4:05 PM
G Online: Sleepy
Never owned a car in my life. Caps go in pocket. Curious though my pickup with a relocated fuel tank and filler to fender,
vents upon itself but no vent at the cap. Works fine.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Gazz #1607543 07/10/2026 4:11 AM
Same gas cap and vent arrangement I used on my '57 GMC, Guitplayer. My tank was a junkyard special I pulled from a mid-80s Mazda pickup.
