0 members (),
132
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2020 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2020 Posts: 43 | I was online reading about a 1959 chevrolet Viking LCF truck. Sources said an optional package with a 283 was a six speed Powermatic transmission (not powerglide) with a 3.73 or 3.55 rear end. I have never heard of this before. I bought a chevy manual for Powermatics. So that will take 42 weeks to get here. Has anyone heard of this, and can you tell me anything more about either the transmission, or the package with a 3.73 rear? On a huge Viking LCF truck??? I just had no idea that the beast existed. Thanks for any details. Mike. | | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Mike - You can dive into details on the 1959 Chevrolet Viking LCF and optional equipment here in the 1959 Chevrolet Truck Data PDF from the GM Heritage Center. Here's another resource, 1959 Chevrolet Truck Engineering Features to add to that info above. Happy reading.  Let us know if there's more you'd like to know.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Mike - After a little more digging through resources, it looks like the initial offering of a V-8 (265) and 6 speed Powermatic transmission package was in the 1956 Chevy LCF line HERE. As '56 was the first year offered, the 1956 Chevrolet Truck Engineering Features pamphlet has a detailed section with most anything you may want to know about the "Powermatic". By '59, the information wasn't included in that year's pamphlet as it was considered "old news". I couldn't find anything that indicated '59 LCF's (5000-9000 Series Trucks) were equipped with 3.73 or 3.55 rear axle ratio's. The axle ratios for both standard/optional single speed and 2 speed rear ends are specified in the previoulsy linked 1959 Chevrolet truck Data PDF. So the "beast" with a V-8 and 6 speed Powermatic's exist, just not with either of the axle ratios you mentions.
| | | | | Joined: Oct 2020 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2020 Posts: 43 | Thank you Gdads51! Just what I was looking for, and a lot more. The gear ratios include 3.31, 3.55, and 3.70; so close to what the online comments were suggesting. Close enough for me anyway. I assume 3.31 would use lower RPMs at highway speeds, and a 3.70 would yield better acceleration, with 3.55 being an in between compromise. I'm wondering if all of this implies a one speed rear end instead of a two speed rear end with a power matic transmission? For a driver, not a heavy hauler, what gear ratio would anyone choose? Thoughts? Now, where would a person find a powermatic? They were made at least from 1956 through 1960. Thanks again! | | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | If the specs show only one gear ratio per option, it is a single speed rear differential. If you are looking at a truck to purchase and it has a Chevrolet V8, it will bolt up to any Chevrolet spec'd automatic tranny, power glide, turbo 350, turbo 400, 700R4, 4L60, 4L80, and more.
| | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Mike - I'm not sure what "sources" you're referring to, but the LCFs are "Big Bolt" trucks (1-1/2 ton and up) and those gear ratios you just mentioned were not available for the big trucks. In fact for 1959 the only ratios listed being offered for the 1/2 ton trucks is a standard 3.90, and optional 3.70, 3.38 and 3.92 Posi-track gear sets. None of the 3 ratios you list were available in Chevy LCF trucks for 1959, with or without the optional Powermatic as that transmission was only available for the "Big Bolts". As far as your understanding of the affects of each of those ratios for engine rpm and acceleration, your not wrong. There's just no connection between those ratios, that were all single speed axles in pickup/panels/Suburbans and the Powermatics and "Big Bolt" single or 2-speed axles. With all that being said, I'm going to move this thread to the Driveline forum as that's the best place to continue discussing transmissions and rear axles.
| | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | The Powermatic transmission is actually an Allison 6-speed automatic with a retarder pedal located where the clutch pedal would normally be (looks like a gas pedal), this allows the transmission to be use for down hill speed reduction saving wear on the brakes. There were changes/improvements made over the years from it's introduction in 1956, for example in 1958 they added a second Drive range and changed the look of the shift tower. The different applications are identified by the color of the Allison Data Plate (like red, green, yellow) that were riveted on the side of the trans case. Mike B  | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | It was offered in 1957, and the truck shop manuals from then on had the overhaul info in them, up until it was not an option anymore.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | It was offered in 1957, and the truck shop manuals from then on had the overhaul info in them, up until it was not an option anymore. The Powermatic (Allison) 6-speed automatic was first offered in a Chevrolet truck starting in 1956...It's also in the 1956 Supplement Shop Manual. Mike B  | | |
