| | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 89 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 89 | I found a listing for a 1523089 Fuel Pump on the cheap, I see it's listed for 1937-51 trucks only. Will this work on a '55? Thanks!
1954 3600 Stakebed non-original engine out of a '55 passenger car with powerglide
| | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | The angle of the inlet and outlet ports changed in mid year 1955 to clear the center position motor mounts. Early pumps had the ports front and rear- - - -newer designs had them at 45 degree angles. Jerry
| | | | | Joined: Sep 2009 Posts: 5,830 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,830 | Oswald- Isn't your truck a '54 3600? The '51 fuel pump has the same output rate/psi as the one listed for 1955.2 Series engines, so it will work as far as performance, as well as fitting in your engine compartment as your '54 mount setup won't interfere with the fuel line plumbing. If your truck was plumbed for the later style pump mentioned by Jerry, it's not that hard to change your fuel line layout to work with the earlier pump ports.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jun 2018 Posts: 89 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 89 | Thanks for the info, yes you are right. It's a '54 3600 so I guess it's just a plumbing issue. Which is fine by me since all that plumbing has yet to be done.
