8 members (ShopRag, TUTS 59, 1955 1 Series, Deegs53, dt235sd, treegrower, Otto Skorzeny, 1 invisible), 71 guests, and 2 robots.
Topics128,265
Posts1,058,138
Members48,482
#1606487 06/25/2026 10:44 PM
Which 1966 C10 trucks came with 10 bolt rear axles and which came with 12 bolt? Thanks.
Professional Novice
Frank - From what I can deduce reading through the 1966 Chevrolet Truck Data PDF, the 12 bolt cover rear axle was the regular C10 unit with 1 standard and 2 optional gear ratio sets. Only '66 K10 series trucks were equipped with leaf springs instead of the coil spring trailing arm rear suspension and used the DANA 44 rear axle with the 10-bolt cover.
Confirmation of the different axles and rear cover bolt counts was done by researching many resources plus Chevrolet Master Parts Books. I can provide more details if desired, but that would have to wait until another day as this one is closing out fast. smile Below are just some of the resources I searched to help find this info.
~ Dan
1951 Chevy 3 window 3100
Thanks again!
Professional Novice
GMC used Dana axles, might have been swapped into your chevy. I've got a Dana 44 from a GMC under my "60 C10 Apache.
BC
1960 C60 pasture art
