9 members (55shaker, GMCJammer51, GIJOE298, Jay R, Otto Skorzeny, Gray_Ghost, Ridgeback, Peggy M, NJC), 118 guests, and 0 robots.
Topics128,157
Posts1,056,894
Members48,458
#1605923 06/18/2026 12:34 AM
I’m at what little I have of my wits’ end. I have a 1964 Chevy 327 in my 57 NAPCO truck. The engine has about 200 miles on a rebuild. It runs well, but I have a leak that appears to be coming from the rear main seal area. I replaced the standard 2 piece seal with an offset type from FelPro, and I have the same leak. I used tracer dye and I don’t see any other evidence of leaking other than around the engine side of the flywheel. The crank was ground .020” if that is a clue. My PCV system passed the pinch test on the hose and nothing’s blowing out of the oil fill tube.
Thanks for any ideas.
Larry
Crusty Old Sarge
Crusty Old Sarge
Was the seal surfaced machined as well? Could be you need to use a Redi Sleeve on the seal surface.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
The surface of the crank is smooth all over, but there’s a barely noticeable step between the seal surface and the bearing surface which is why I tried the offset seal. I suppose I’ll need to take it apart again and check where the seal hits relative to the step. I thought I did that, but at my age who knows.
A 327 V8 can't use a speedy sleeve- - - -the flywheel flange is bigger than the seal surface area. Try gluing a strip of shim stock to the back side of the seal to squeeze it a little tighter against the crankshaft. Use high temperature epoxy, which should be pretty oil-resistant.
Thanks for clarifying that. I was wondering how I could do that. I’ll try the shim and let you know
