3 members (baldeagle, Shade Baby, 1 invisible), 94 guests, and 4 robots.
Topics128,125
Posts1,056,336
Members48,439
#1605552 06/12/2026 4:09 PM
Time to install new frost plugs, as well as the camshaft bearing plug, I’m guessing the frost will be a standard size. What about the camshaft bearing plug? Is this part specific to this engine series?
Same 2326195 part number from 1939 228" engine to 1960 302".
Dave - Check out this previous thread on the GMC 6 front and rear freeze plugs and camshaft bearing plug. Was in response to a GMC 270 question, but as Bill says, they are the same.
My part numbers came from an earlier GMC Parts Books resource than Bill's part number, but as far as I know they are the same plugs. After seeing Bill's provided GM#, I found it listed in the 1963 GMC Master Parts Book. This reference doesn't provide dimensions, but the same GM# is listed for Chevy applications and one description listed the cam bearing plug dimensions as "rear brg. cup (1-63/64")". For whatever reason, my previous search didn't turn up Bill's part number. headscratch
Did you need info on the block side "frost plugs" too?
~ Dan
1951 Chevy 3 window 3100
Yes, regarding the side frost plugs, if you find the Dorman pt number that would simplify the search, thanks !
Dave
The side of block core plugs (5) are originally GM# 663032 - Plug, cylinder block 1-1/4" OD (cup style).
You can get Dorman 555-023 which is a 1-1/4" OD cup style "steel" core plug, or Dorman 565-023, which is a 1-1/4" OD cup style "brass" core plug. wink
~ Dan
Thanks again !
