4 members (ndkid275, Wally / Montana, Hanks custodian, dt235sd), 88 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
Hi All,
My name is Dean and I am from Western Australia. I recently bought a 1950 5-window 3100 barn find. I think it might have spent its life on a Californian farm as it was riddled with Walnut shells.. headscratch
There is minimal rust just in the cab corners -- luckily it came with the patch panels.
The engine is not salvageable so the whole drive train will be removed and replaced with a 350 SBC and a T700 combo.
As I live in a RHD country, I will also do a RHD conversion which also includes cutting up the dash and switching that over as well.
smaller view for embedding in first post. ;)
~ Dean 🇦🇺
1950 Chev 5 window 3100
"Barnfind in Australia"
Follow in the DITY
1957 Chev Factory RHD, body off Restomod, 454 BBC, TH400, 9inch
Welcome aboard Dean. That’s a nice solid looking truck you were lucky enough to find. Congratulations. I’m looking forward to watching your build.
1950 3100w/63K
Farm Truck: Fame-up restoration / modification
Follow the restoration story in his Project Journal
1950 Styleline Deluxe Coupe w/93K
Thanks Paul
~ Dean 🇦🇺
Follow in the DITY
Once again, Welcome to Stovebolt Dean! wave Your project goals are doable, given the necessary resource, time and so on. wink Looking forward to seeing your project get going. smile
~ Dan
1951 Chevy 3 window 3100
Former Workshop Owner
Cool truck. 👍 I’ve always liked those rear bumpers. Tailgate looks nice and straight. Good score.
Welcome
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Thanks John, it does make climbing in and out of the bed easy, but I'm not sure of the look though.
~ Dean 🇦🇺
Follow in the DITY
So I have bought a Jag Series II IFS Rack n Pinion front end from an old Hotrodder which will need a full rebuild, from the 4 pot brake callipers to the rack n pinion, and suspension……
Last edited by Gdads51; 06/19/2025 2:05 AM. Reason: removed pic link text from message body to allow for full pic display
~ Dean 🇦🇺
Follow in the DITY
Gasp, you’re treading close to heresy now Dean 😂. I just got my new Mustang ll IFS x member the other day, but haven’t put it together yet.
Interesting choice for yours. How much work do you think it’ll be before you’re ready for the install?
1950 3100w/63K
I’ve had to make up some elaborate brackets to mount it to the chassis as I don’t want to weld it in, so I am about to put it all together and mock it up to see if it will all work, so hopefully Paul it should be a couple of weeks
~ Dean 🇦🇺
Follow in the DITY
So I have finished up on refurbishing the jag front end suspension and rack n pinion and now have got it in position ready to be mounted in
Out with old in withe new
~ Dean 🇦🇺
Follow in the DITY
Now the process of mounting the front end begins, and fabricating some shock mounts as well.
~ Dean 🇦🇺
Follow in the DITY
After a bit of fabrication, welding and painting the front end is ready to go in
~ Dean 🇦🇺
Follow in the DITY
B Online: Content
You are going to have a hard time getting the steering column through the hole on the firewall, through the engine and then to the input shaft on the rack and pinion. wink
U
U Offline
Is the steering rack reversed? Is the input shaft on the passenger side? I think I'm seeing what Bill is seeing.
~ John in Utah
Here We Go
Follow in his DITY Bay
Gents - He mentioned above that he's converting it to Right-Hand Drive (RHD). wink
~ Dan
U
U Offline
Oh, now I see he's from Down Under! Sorry about that Dean.
~ John in Utah
Here We Go
Yes that’s correct, I am converting it to Right Hand Drive as I live Down Under in Australia.
~ Dean 🇦🇺
Follow in the DITY
AD Addict & Tinkerer
Please join me in giving a warm Stovebolt welcome to the latest Project Journal forum contributor, Shardean! Dean joins us from Perth, Western Australia, and he has some truly big plans for this former California truck.
Dean is already demonstrating some impressive fabrication skills. He has sourced, rebuilt, and installed a Jaguar Series II IFS front end—taking care of everything from the 4-pot brake calipers to the rack and pinion steering and suspension. Since the original engine is beyond saving, he plans to pull the entire drivetrain and replace it with a 350 SBC and a T700 combination.
Because Dean resides in a right-hand drive (RHD) country, he is also undertaking a full RHD conversion, which includes the significant task of cutting up and reconfiguring the dash.
It is a lofty dream from halfway across the world, but Dean clearly has the talent and the determination to see it through. What’s not to love about a project like this?
We are very much looking forward to following along as Dean’s vision unfolds. Welcome aboard, Dean! You can view his Journal from the begining here.
Best regards,
Phil (Phak1) Hakala Moderator, Project Journal Forum
Phil
Project Journals
Stovebolt Gallery Forum
So next on the agenda is to tackle the dash conversion. This took a lot of thought and measuring as to which way to go about it, and I like the idea of having the Glove Box in the middle of the dash for easy access. I had to fill in the radio holes as one of the final cuts passed straight through it.
~ Dean 🇦🇺
Follow in the DITY
Are you planning to relocate or duplicate the support bracket that goes fromt he dash to the firewall on the original driver's side? Porbably a lot easier to do that before you put the portions of the dash face back in place.
1949/50 3600 Project
Follow in Project Journals
I was thinking that the support bracket was for the steering column so it wasn’t needed to be put back in, but I do intend of putting one in on the right hand side. I will fabricate something up once I have worked out the pedal box situation.
~ Dean 🇦🇺
Follow in the DITY
I think you'll need that support bracket moved to the right side, or at least put some sort of support for your RHD steering column. For what it's worth, my steering column support bracket was cracked at the lower end, and when I put it back in, I needed to remove the tacked in bolts that go thru the firewall in order to get it back in place, because it was then too long to jockey into place. I replaced the tacked-in bolts with carriage bolts.
Support bracket with ends cracked off.
Repaired - now too long to fit back in.
Thanks Kevin, I won’t be able to use the original bracket as it won’t fit the new steering column I will be using, but i do intend on making a bracket up.
More photos of the cut and tuck
~ Dean 🇦🇺
Follow in the DITY
Moderated by  Phak1
