4 members (GMCJammer51, 54farmtruck, 2-Ton, treegrower), 74 guests, and 3 robots.
Topics128,196
Posts1,057,395
Members48,471
U
U Offline
Anyone know what this clip/pin is called? I would like to pick up a spare or get an idea for an alternate spare. Thanks!
~ John in Utah
Here We Go
Follow in his DITY Bay
Generically Hillman calls it a hairpin clip
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
U
U Offline
Thanks Chuck. I'll try searching for that clip.
~ John in Utah
Here We Go
John - It's known in the Chevy Master Parts Books as "Spring, lock" or 'Retainer, hairpin" depending on which part of the vehicle it is being used on. smile
GM# 355936, Spring, lock - Parts Group 0.837 as in your application, or Retainer (hairpin - 1-3/4 long), Parts Group 0.376 as the retainer at the ends of the 216/235/261 rocker valve shafts.
No one appears to be offering any of these on-line, but you could snag a few from a derelict engine easy enough.
You could also experiment and try to find an E-clip with the same shaft diameter to use in place if all else fails.
~ Dan
1951 Chevy 3 window 3100
A couple of numbers that may have the pin.
Vintage Chevrolet parts
1-760-723-5135
Old Car Parts
1-503-771-9416
Tom Myers truck parts
1-918-533-3871
I have bought parts from all of these guys all nice to work with
1946 Chevy Truck 216 1/2 ton
"Tales from a weekend mechanic"
Follow in the DITY
U
U Offline
Thank guys! Great information.
~ John in Utah
Here We Go
U
U Offline
Originally Posted by Gdads51
... Parts Group 0.376 as the retainer at the ends of the 216/235/261 rocker valve shafts.
I've not checked, but does that mean I have one under my old 216's valve cover?
~ John in Utah
Here We Go
Yes sir! Should actually be 2 of them hiding under there just waiting to be scavenged - lol! grin
Last edited by Gdads51; 05/30/2026 2:19 AM. Reason: fixed with correct assembly picture
~ Dan
I would say - YES.
Dan beat me to the punch, but there's only two per engine.
Valve Rocker assembly end hairpin clip
U
U Offline
Great! It's good to know I have some spares. Hopefully I'll not need them, but still good to know.
~ John in Utah
Here We Go
7
7 Offline
If you are not concerned about authenticity, hair pins for hitch pins are available in a wide variety of sizes, hardware store small specialty bins will be the place to look.
U
U Offline
Thanks. I was thinking about those too. A friend said I could drill a hole through the mount, but I don't think I'll do that for now. Since my old 216 has a couple, I'll probably take one of those for the spare parts bin.
~ John in Utah
Here We Go
