2 members (WICruiser, Bill Hanlon), 251 guests, and 1 robot.
Topics128,089
Posts1,056,143
Members48,436
I need a source that can restore my heater box and capillary tube thermostat. and maybe change the motor to twelve volt.
Thanks Red
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
Red - I added a little detail to your title to try and help get the best help for you.
Which heater do you have? The Truck Air Flow Heater or Truck Recirculating Heater. headscratch
~ Dan
1951 Chevy 3 window 3100
The parts to repair your heater are widely available. It's easy to do yourself. I purchased a new heater core assembly from Classic Truck Parts.
12v motors are available to replace the 6v motor.
For rebuilding services for just about everything, contact Then and Now Automotive. Call them. Website isn't really helpful. Also contact Atwater Kent for your capillary tube.
447 Washington St
Weymouth, Ma 02188
Ph: 781.335.8860
Fax: 781.335.1925
https://www.thenandnowautomotive.com/auto-parts-store
Temp sending units, coils, fuel sending units, tube radios, 1920s to 1970s (mostly 30s, 40s, 50s)vacuum advance, voltage regs
Atwater Kent
12 Jacques Street Worcester,
MA, 01603
(508)792-9500
http://www.mykmlifestyle.com
1950 Chevrolet 3100 (Ol' Roy)
Moderator, Electrical Bay
Red, if you aren't trying for 100% original, you can make your own heater coil using a 10 foot long roll of 3/8" copper tubing, a couple of 3/8" to 1/2" copper plumbing adapters, a couple of apx 6 inch long pieces of 1/2 inch copper tubing and the framework your current and leaking heater core is soldered to. Basically you just get an old style coffee can, piece of PVC drainage pipe or anything with the right size inside diameter and wrap your tubing around it, spacing about 1/4" between each pass of the coil. You can use small (1/4 inch square) pieces of wood to keep them spaced apart. Just make a coil that will fit inside your heater shroud and get the connection pieces in the same place, solder that to your old hardware and you're finished for about $35. Changing to 12v will be easy. Actually I gave away a USA made 3 speed 12 volt motor free for cost of shipping a few months ago. As for the capillary tube thermostat, you can get one rebuilt (will not be cheap) but unless you are just dead set on having one of those as per original, there are alternatives. I've sure had a lot of leakage problems with them. I will tell you the heater coil I made like that put out a lot of heat, worked well in defrost mode and I just used a common cable type heater valve that cost about $15. Good luck!
~ Jon
If you have a ranco valve heater control then there is a guy in Superior Wisconsin that has come up through the years so I think he is good .You can also a temp to fix yourself as the parts are available and lots on the net to look at .as far as the heater box just a matter of cleaning it up and paint ,then of course the heater core either repair yourself as or buy new .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Rebuilder of Ranco and RobertShaw heater valves. New Ranco heater valves for sale
Joe Hudacek
6606 Banks Avenue
Superior, Wisconsin 54880
715-392-6169
Cell: 218-213-8906
http://www.heatervalves.net/
Moderated by  ndkid275, Phak1
