6 members (TexasJim50, 1955 1 Series, stlcardinalsguy, 2-Ton, Oswald, cmayna), 73 guests, and 4 robots.
Topics128,180
Posts1,057,157
Members48,464
Page 8 of 9 1 2 3 4 5 6 7 8 9
Guitplayer #1577959 05/22/2025 11:42 PM
I must be doing something wrong.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Guitplayer #1577960 05/23/2025 12:08 AM
O Online: Content
BD,
I think you need to stop and go back to the basics.
Get #1 piston at TDC by taking out the plugs and turning the engine over by hand with your thumb over the hole (or with a drinking straw in the hole).
When your thumb is blown off the hole or the straw goes up to its highest point, look at the position of the distributor rotor. It should be pointing at the plug wire that is going to #1 cylinder. If it isn't move whatever wire is connected to #1 plug to that dizzy position.
After that, make sure all the other plug wires follow the firing order and that all are going to the correct cylinders.
Now your engine will be properly timed to the factory baseline. Set the octane selector on the dizzy to zero. Start the engine and see how it runs. With your timing light you can advance or retard the timing as required.
1950 Chevrolet 3100 (Ol' Roy)
moparguy #1577988 05/23/2025 2:46 PM
You are too kind RonR!
Jim Linder at Bubba’s Ignition was rebuilding my distributors. Bubba retired and was having a few health issues. So I purchased and rebuilt a Sun machine and Jim Linder walked me through the basics. He unfortunately passed away in December 2023. He was a really good guy. So now I rebuild my distributors myself.
After having gone through quite a few distributors now, I have a new appreciation of what a difference a correctly functioning distributor can make.
Mike
Guitplayer #1577989 05/23/2025 3:26 PM
Idle set timing 14 degrees. All is as good. Runs good. Starts right up.
Simple is right. Thats where the engine runs the best.
~ BD.
Guitplayer #1577990 05/23/2025 4:03 PM
Indulge me just a bit, how did you get to the 14 degrees btdc?
Mike
Guitplayer #1577992 05/23/2025 4:33 PM
When I build up a stovebolt engine, I fabricate a pointer and file a TDC reference line on the crankshaft balancer. Then I can use my Innova delay flash timing light to check spark advance and set the initial timing. I've got a Sun distributor tester like the one in the above picture that needs a good rebuild. The xenon flash tubes for the Sun testers are no longer available, so I use the same delay flash timing light to check the advance curve.
Guitplayer #1577996 05/23/2025 5:59 PM
I`ve had enough time to set the engine various different ways and drive it.
There is a very short turn one or the other CW/CCW with the DIST to have the motor sounding and running smoothly
at idle. Having tried most every mark in that narrow sweet spot. It turns out with my timing light scrolled to
14 and at idle the pointer lines up. Then went to the air mixture and found its spot with the VAC gauge where
it started losing + got it back to that point and backed off 1/8 of a turn.
I can get to 52mph let off the ACCEL and then tap the ACCEL with my foot and it`ll respond. The engine is what it is and
like what was said before ..I`d bet only 100-110hp.
~ BD.
Guitplayer #1577999 05/23/2025 6:28 PM
Then you are where you ought to be! Well done!
Mike
Hotrod Lincoln #1578000 05/23/2025 6:31 PM
Jerry, get to Mark at the Paramount Distributor website.
Mark has recap kits to get the electronics up to par, and if yours is old enough to use a battery, he has a conversion kit for that. He also has belts, rubber parts, all kinds of stuff.
He also has a led conversion for the flash tube and sells used but working tubes when available.
http://paramountd.com/parts.html
Mike
Guitplayer #1592533 11/22/2025 9:47 PM
Update on the 1957 235. I pulled the engine and we took it apart. CYL walls are worn.
#5 piston had a split ring. Thats what caused it not to get compression, All pistons have slop there with the rings.
I`ll have some questions about the next size up pistons I can use. Everything is getting cleaned.
Running that mix of marvel mystery oil and engine oil really cleaned the engine for disassembly.
~ BD.
Guitplayer #1592536 11/22/2025 10:15 PM
O Online: Content
Your engine guy sure has a lot of nice old equipment.
Guitplayer #1592545 11/22/2025 11:03 PM
. these guys are really slow. I would not use them again
~ BD.
Guitplayer #1592793 11/25/2025 11:50 PM
Looks pretty good, really. Crank looks pretty shiny, bearings not ridiculously shot, no excessive contamination. For as old as it is, not worn too badly. Must have been taken decent care of, for the most part.
Guitplayer #1592800 11/26/2025 12:05 AM
amazing I got 60mph+ on 5 limping underperforming CYL`s.
#5 had a split ring.
That 60/40 mix of oil and MM oil cleaned things up great. Running at a mid RPM for 20 min.
~ BD.
Guitplayer #1598542 02/24/2026 7:23 PM
getting there.
~ BD.
Guitplayer #1598573 02/25/2026 1:59 PM
How much did they take off on the deck?
~ Dan
1951 Chevy 3 window 3100
Guitplayer #1598581 02/25/2026 2:47 PM
Could not tell ya. whatever they had to I guess
~ BD.
Guitplayer #1598583 02/25/2026 2:54 PM
Just a suggestion, but there have been recent post on the topic of decking the engine as it may affect other aspects of the engine rebuild/reassembly. At a minimum, you probably want a record of the details of the machine work, amount decked, amount over bored, etc. to keep handy for when it gets to the reassembly stage.
Are you planning to do the reassembly, or is the shop on that task?
~ Dan
Guitplayer #1598585 02/25/2026 3:23 PM
shop will reassemble
~ BD.
Guitplayer #1598591 02/25/2026 7:40 PM
Block decking is usually only a shallow skim cut to assure good head gasket sealing. Head milling is more complicated, as it can result in intake valve burning and altered rocker arm geometry if too much material is removed from the head.
Guitplayer #1598594 02/25/2026 8:32 PM
Thanks Jerry!! Im expecting this to be a high quality build. .
Parts are coming in now. We know specs. I`ll get it. Paint it and install. Best part is the rest of the truck is
ready to go. Titled and tagged. This is my first off frame.
~ BD.
Guitplayer #1598596 02/25/2026 8:51 PM
and Jerry one of the best guys to talk with. Extremely knowledgeable. Good man.
~ BD.
Guitplayer #1598600 02/25/2026 9:13 PM
Question??? Does a person HAVE to have the info of the amount of shaving was done from
BOTH head and block? If they don't have that information, what can be done to ensure the head and block can be married correctly?
S2
Stewart2
1955.1 3100
Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC
Jack of several trades and experiences; Master of none
Guitplayer #1598603 02/25/2026 9:48 PM
It's a simple matter of measuring everything- - - - -intake valve seating, piston-to-deck clearance, crankshaft journal dimensions, connecting rod specs, cam timing, pushrod length, and about half a dozen less critical dimensions that can stack up to either work well together- - - -or not. The newest stovebolt six engines are over 50 years old, and the basic design goes back to the late 1930s. There's no telling how much they've been whittled on during that time- - - -some have been "rebuilt" several times, so the specifications our resident number crunchers like to quote as if they came down from Mt. Sinai chiseled in stone are SWAGs at best. Just like Sun Electric Co. used to say- - - - -"We Test, Not Guess!"
Guitplayer #1604128 05/20/2026 10:23 AM
well these guys have the engine. nudging might help.>
~ BD.
Guitplayer #1604133 05/20/2026 12:41 PM
I`m finding mabbco....+ S and J
~ BD.
Guitplayer #1604140 05/20/2026 1:29 PM
BD - Is this the "mabbco" you are asking about??? Same question for "S and J"???
I don't have any personal experience with this "mabbco", but I would highly suggest checking/reading their BBB (Better Business Bureau) web report. The one I saw would make me disinclined to consider them IMHO.
Same lack of personal experience with "S and J", but at least they are rated by the BBB as A+ and their very short list of customer complaints would make this one possibly a better choice, again just IMHO.
Have you asked fellow Great Lakes Bolters for possible better area rebuild shops or closer to you engine suppliers?
I think some of our fellow Bolters should have some insights and suggestions for you. wink
~ Dan
Guitplayer #1604212 05/21/2026 12:06 PM
PM sent
Guitplayer #1606358 06/23/2026 9:01 PM
guides and liners upgraded to bronze. its moving along.
~ BD.
Guitplayer #1609234 08/10/2026 5:21 PM
Latest pics ......
~ BD.
Guitplayer #1609235 08/10/2026 7:23 PM
Don't let the machine shop talk you into installing "hard valve seats". They're not needed, and the procedure sometimes causes the head to crack. Use stainless steel exhaust valves for a small block Chevy V8 instead. (Costs less, too!)
Guitplayer #1609277 08/11/2026 11:24 AM
Yep!!
~ BD.
Guitplayer #1609729 08/18/2026 10:39 PM
thumbs_up
~ BD.
Guitplayer #1609801 08/20/2026 12:29 PM
Crusty Old Sarge
Crusty Old Sarge
Your 235 is keeping some good company there Lots of Toys in the background... Its coming together dance
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Guitplayer #1609913 08/22/2026 10:30 PM
Back home safe a sound. Paint then install.
~ BD.
Guitplayer #1609932 08/23/2026 6:15 PM
2 coats primer....3 coats blue and 2 coats clear. Flywheel and clutch next. Just have to install.
Then set in place.
~ BD.
Guitplayer #1610029 08/24/2026 9:53 PM
engine back in the truck.
~ BD.
Guitplayer #1610492 08/30/2026 10:54 PM
oil pump primed and engine ran 30 minutes at 2000 rpm. I`ll change the oil very soon but wanted to get
some road miles...maybe 20 miles or so at 45 mph does this seem like a good approach?
~ BD.
Guitplayer #1610494 08/30/2026 11:06 PM
C Online: Content
Sounds like the motor will purrrrrrr at 45 mph.
Craig
cmayna #1610498 08/30/2026 11:53 PM
You need to do some wide open throttle acceleration / closed throttle deceleration at road speed to seat the piston rings.
BC
1960 C60 pasture art
