7 members (55shaker, MickeyP, KCMongo, Otto Skorzeny, Wally / Montana, Gdads51, Nick in Manitou), 106 guests, and 0 robots.
Topics128,050
Posts1,055,704
#1604108 05/20/2026 2:06 AM
I had my 6 volt starter rebuilt about a month ago and he converted it to 12volts. Today I was driving down the road and literally heard a roaring noise from under the hood. I pulled over and turned off the truck and discovered that it was the starter and it didn't stop roaring until I disconnected the battery. After I reconnected the battery it wouldn't start or make the noise. What the heck happened?
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
Sounds like the big copper contacts on the switch on top of the starter welded themselves together. Take that switch off and see what the contacts look like.
Is the return spring on the stomp linkage in place?
The original 6 volt starter does not need to be converted to 12 volts so not sure what was done as the starter will run off 12 volts fine as long as you don’t over use it on cranking .the 6 volt starter does need to be matched up to the proper flywheel .I would go back to the rebuilder to find out what he did .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
