1 members (baldeagle),
48
0
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 56 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 56 | Hey all,
Working on a project for the 52. Love to know if anyone has a machine shop they know of that has experience with these engines around the lower mainland.
After a ton of pressure to do the same old boring LS swap so many have done I think I’ve settled on moving forward with a tried and true classic. I have a 292 that I pulled from a runner a few years back but 2020 happened and other priorities (like finding toilet paper) took precedence. Fast forward to present and I’m finally ready to move ahead this year.
Before I install it though I do have some work that I’d like done to give it a bit more airflow and a little added power.
Any suggestions on a good shop to use?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Matties, the machine shop behind Fortins supply in Chilliwack may be a good place to call about your project, they changed their name a while ago I'll try and find their new name, the shop owners name is Norm. | | | | | Joined: Oct 2014 Posts: 56 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 56 | Thanks, appreciate the lead! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Matties, I finally found the information, the shop name is NC Engines, phone number(604) 795-9739 | | | | | Joined: Oct 2014 Posts: 56 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 56 | Amazing Bobb. Thanks! I tried calling a few shops around and didn't get very far. Lots said they "can" help me, but hoping for a shop with some experience . | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | A 292 in a 52 chassis will have a problem with the position of the fan and water pump- - - - -way too low on the original radiator location for good airflow. You'll either need to get creative with a fan shroud shape, or design a jackshaft to raise the fan position in relation to the water pump. Jerry
