4 members (Otto Skorzeny, FAST55, Hawkman, 52GMC35424JD), 91 guests, and 1 robot.
Topics128,051
Posts1,055,768
#1603029 05/03/2026 12:46 AM
Thanks to a lot of helpful advice 8 months ago I finished rebuilding my '49 Hydrovac, and finally installed it last week along with new master cylinder. However I didn’t put the oil in its tank yet, where would you pour it in? And how much? I know it’s not much, maybe a cup or less. I read of one guy using mineral oil, does that sound right?
Thanks much
1949 Chevy 6400 two ton, 2 speed rear end, 235 engine, 13 foot hydraulic dump bed.
Can you take and post pictures of the rear of the Hydrovac canister body? From what I've read in the shop manuals, there seems there should be an oil filler plug on the back side of the main canister that is where the oil should be placed. The 1948-51 Chevy Truck Shop Manual (see below) in the rebuild reassembly instructions for the Hydrovac says to fill to the level of the filler plug. It does not indicate a capacity there.
In the Lubrication information portion of the shop manual (see second pic below), the portion covering the Hydrovac says "One ounce of Bendix Vacuum Cylinder Oil should be added every 10,000 mile intervals or each six month period...".
My guess since you just reassembled it after rebuild would be to fill to the level of bottom of the filler plug, then maintain based on mileage/time as noted in routine service.
On the type of oil to use, many recommendations I read about to replace "Bendix Vacuum Cylinder Oil" which is no longer available, is to use "Neatsfoot Oil". It's formulated to be used on leather products, so should work for your new components.
~ Dan
1951 Chevy 3 window 3100
Big Bolt Forum Co-moderator
I used mineral oil in mine.
1948 Chevy 2-Ton
7
7 Offline
The Bendix HydroVac has a small pipe plug (1/8" npt) at the bottom front of the vacuum canister, fill to the level of the plug with the unit in a level horizontal position. The oil is only to keep the leather vacuum piston seal pliable, as the piston moves within the cylinder, the oil wicks its way around the leather. I used motorcycle shock oil.
Good to know, thanks for all the good info. I'll be back out there in a couple days and get it done. I was thinking it might wick up to the top. When I took it apart there was only about a teaspoon of oil in it, but the brakes were still working pretty good. I only took it out to make sure it was in top condition, as long as the master was off.
I have been curious about this as well. I looked and sure enough there is a plug on the front end of my Hydrovac unit. Here is a picture, the plug has a square head. The diagram in my 1955 shop manual does not show this plug, but it gives a clear description of the operation. Focusing on this plug, a simple description:The power cylinder has vacuum in it on both sides of the power cylinder piston when the engine is running and the brake pedal is not being pressed. When the brake pedal is pressed, atmospheric pressure is applied to the front end of the power cylinder. So from this the plug needs to be air tight. I've never added oil, I will now.
Hydrovac
Hydrovac diagram
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Yeah - The cutaway drawing in the manual through me for a loop until I looked at an actual hydrovac too.
~ Dan
