5 members (Robert Crandall, Danielbolt, Phak1, Bill Hanlon, 1 invisible), 325 guests, and 5 robots.
Topics128,156
Posts1,057,021
Members48,460
Donald S.
Donald S.
This is the front suspension support (torsion bar) on a 49 suburban. I am pretty sure this will work on 49-53 trucks also. Includes all brackets and bolts.
Edit note - This thread was originally in the Truck Parts For Sale forum but has been edited for content to save the technical knowledge and info for fellow Bolters to see and share as it may apply to their trucks. Many thanks to the participants for sharing this info. thumbs_up
Torsion bar
Last edited by Gdads51; 06/24/2026 3:17 PM. Reason: Moved/changed into an information post for Driveline
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
Donald - this style was originally used on 1947-50 Suburbans and Panels, but can also be used on the later 1951-55.1 Series from what I've read on the subject.
Thanks for sharing! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Professional procrastinator
That looks very interesting to me.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
B Online: Content
The mounting arrangement for this Chevy sway bar is different than a similar bar for a GMC. The mount points on the Chevy frame are parallel to the ground while the GMC mount points are angled quite a bit. I can take a picture of mine to compare to Donald's picture.
Donald S.
Donald S.
Guys, I also have this picture. It should help with detail.
1953 Chevy 5-window
Bill, That would be great. Thank you. I did not know there might be a difference in the mounting points.
Well, for all those that might search for this in the future, Mr. Hanlon is correct. The GMC and Chevy sway bars mount differently, so it won't fit on my truck. I have attached a picture of the GMC mount and you can see they are angled to accommodate the angle of the frame crossmember. We never stop learning do we. Thanks for posting.
Donald S.
Donald S.
Best we figured it out now instead of later. 👍👍
1953 Chevy 5-window
Amen to that. Thanks again Bill Hanlon for the heads up.
Great sharing effort everyone to help ID that there is a difference between Chevy and GMC front sway bar mounts! thumbs_up
~ Dan
