This is the front suspension support (torsion bar) on a 49 suburban. I am pretty sure this will work on 49-53 trucks also. Includes all brackets and bolts.
Edit note - This thread was originally in the Truck Parts For Sale forum but has been edited for content to save the technical knowledge and info for fellow Bolters to see and share as it may apply to their trucks. Many thanks to the participants for sharing this info.
Last edited by Gdads51; 06/24/20263:17 PM. Reason: Moved/changed into an information post for Driveline
Donald - this style was originally used on 1947-50 Suburbans and Panels, but can also be used on the later 1951-55.1 Series from what I've read on the subject.
Thanks for sharing!
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
The mounting arrangement for this Chevy sway bar is different than a similar bar for a GMC. The mount points on the Chevy frame are parallel to the ground while the GMC mount points are angled quite a bit. I can take a picture of mine to compare to Donald's picture.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
Well, for all those that might search for this in the future, Mr. Hanlon is correct. The GMC and Chevy sway bars mount differently, so it won't fit on my truck. I have attached a picture of the GMC mount and you can see they are angled to accommodate the angle of the frame crossmember. We never stop learning do we. Thanks for posting.
1947.2 GMC 1/2T SWB panel 1947.2 GMC 1/2T long bed 1948 GMC 1/2T short bed
Great sharing effort everyone to help ID that there is a difference between Chevy and GMC front sway bar mounts!
