4 members (klhansen, 32Fordpuchoptop, FAST55, walter74), 95 guests, and 2 robots.
Topics128,120
Posts1,056,319
Members48,439
#1603114 05/04/2026 2:20 PM
Hi all
I have a 59 gmc 9400 Canadian truck
14000 lb gvw.
Would anyone have an idea of the weight of the cab and chassis.
No mods, all original, 261, 6 cyl, 4 speed with PTO, two speed rear end.
Don Low #1603148 05/04/2026 10:20 PM
7
7 Offline
Does it have any bed/box right now? My '57 2 ton Chevy Low Cab Forward with a 15 foot cab high wood grain box weighs 7200 lbs. 283 V8, 4 speed/2 speed, GVWR 15000 lbs.
78buckshot #1603153 05/04/2026 11:38 PM
No box. I removed it all as it was rotten, it was a 12’ cab hi box
I was guessing at 6000 lbs.
Don Low #1603154 05/04/2026 11:56 PM
7
7 Offline
With no box it probably is in the 5000 lb range.
Don Low #1603170 05/05/2026 3:56 AM
A 1959 Chevy 6403 (cab and chassis with 156.5 inch wheelbase) and with 14000 base GVW weighs 5120 lb. That should get you in the ballpark. Info from the 1959 Chevy Truck Vehicle Info Kit.
Don Low #1603183 05/05/2026 2:58 PM
1959 9400 trucks 10000-14000 GVW 235-6 Cyl. Or 283-8 Cyl.
9413 (4103 US) chassis & Cab 132.5 wheelbase Curb weight 4465
9443 (4403 US) chassis & Cab 156.5 wheelbase Curb weight 4610
You will have to add a little weight for the 2 speed rear and the auxiliary springs for max. GVW
If it has a 261-6 then someone add it. Check the chassis serial plate it will show the engine size.
klhansen #1603411 05/08/2026 12:04 AM
Thanks for the information
This truck also has a hoist. I would think that’s at least 500 lbs but 750 should give a good margin
78buckshot #1603412 05/08/2026 12:06 AM
Thanks for the info, forgot to mention a twin cylinder hoist also, I’d allow 6-700 lbs for that
