0 members (),
136
Mod | | | Forums66 Topics128,274 Posts1,058,431 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2025 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 17 | Hi all I have a 59 gmc 9400 Canadian truck 14000 lb gvw. Would anyone have an idea of the weight of the cab and chassis. No mods, all original, 261, 6 cyl, 4 speed with PTO, two speed rear end. | | | | | Joined: Feb 2016 Posts: 2,013 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 2,013 | Does it have any bed/box right now? My '57 2 ton Chevy Low Cab Forward with a 15 foot cab high wood grain box weighs 7200 lbs. 283 V8, 4 speed/2 speed, GVWR 15000 lbs.
| | | | | Joined: Dec 2025 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 17 | No box. I removed it all as it was rotten, it was a 12’ cab hi box I was guessing at 6000 lbs.
| | | | | Joined: Feb 2016 Posts: 2,013 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 2,013 | With no box it probably is in the 5000 lb range.
| | | | | Joined: May 2015 Posts: 11,273 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,273 | A 1959 Chevy 6403 (cab and chassis with 156.5 inch wheelbase) and with 14000 base GVW weighs 5120 lb. That should get you in the ballpark. Info from the 1959 Chevy Truck Vehicle Info Kit.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 198 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 198 | 1959 9400 trucks 10000-14000 GVW 235-6 Cyl. Or 283-8 Cyl. 9413 (4103 US) chassis & Cab 132.5 wheelbase Curb weight 4465 9443 (4403 US) chassis & Cab 156.5 wheelbase Curb weight 4610 You will have to add a little weight for the 2 speed rear and the auxiliary springs for max. GVW If it has a 261-6 then someone add it. Check the chassis serial plate it will show the engine size. | | | | | Joined: Dec 2025 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 17 | Thanks for the information This truck also has a hoist. I would think that’s at least 500 lbs but 750 should give a good margin | | | | | Joined: Dec 2025 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 17 | Thanks for the info, forgot to mention a twin cylinder hoist also, I’d allow 6-700 lbs for that | | |
