5 members (Stovebolt48, Wayne67vert, Peggy M, mo2cyl, 1 invisible), 168 guests, and 0 robots.
Topics128,083
Posts1,055,967
Members48,430
#1602443 04/23/2026 6:16 PM
Moderated
Moderated
I have a 1950 2 ton dump truck with a Bendix Series 42 hydrovac booster that was recently rebuilt. I asked the vendor to rebuild the master cylinder but they said it was too far gone and replaced it. We installed the booster and master and got the brake system bled then used the truck for a handful of material runs.
The master cylinder has leaked varying amounts of fluid into the boot at the push rod since reinstall but the brakes worked fine until they locked up on my last run; it seemed like the check valve may have locked up. Relieving pressure on the line at the booster from the master allowed me to get home. We're re-bleeding the brake system following the Chevy Truck Shop Manual. We continue to get air bubbles during the bleed and fluid leaking out of the boot at the push rod.
Thoughts? Would the leaking fluid indicate a bad seal in the master cylinder?
Yes, if fluid can get out, air can get in.
Some of the offshore made products have serious quality issues.
Brakes are not something you want to guess about.
Fred
7
7 Offline
Return the new master for a full refund and find a different brand.
The brakes locking up may be caused by the pedal pushrod being adjusted incorrectly without adequate end play.
But like the other guys said - send the master cylinder back and replace it. It should NOT leak into the boot area.
The original master cylinder can be sleeved with brass or stainless steel- - - - -I hope it didn't get discarded!
Moderated
Moderated
Thanks for the feedback! My first inclination was that I did something wrong with the master cylinder. I'm not convinced that the leaking master and the locking brakes are related. But I'm new at all this!
I currently have a leaky master out of one of my projects, at this place near me, for a stainless sleeve. For me it's a one and done. I maintain a '46 International US Marine WWII Maintainer, most all the wheel cylinders and master leaked. 20 years ago, I brought an axle worth of wheel cylinders for sleeving to this place. The thing sits and is maybe operated once a year. Not a drip since. Everything is done minus one of the three axles. I'm sold! Find someone near you that will sleeve your original master, since originals are less junky than late model versions. If you can get your original back!!
Karp's Brake Service
The misadjustment of the pedal to master cylinder pushrod will close up the relief hole in the bottom of the brake fluid reservoir. If that happens, fluid can't get back into the reservoir when the pedal is released and will eventually lock up the brakes. It shouldn't cause the master cylinder to leak.
