5 members (dt235sd, klhansen, 2-Ton, 52GMC35424JD, Hotrod Lincoln), 79 guests, and 3 robots.
Topics128,049
Posts1,055,665
#1602103 04/18/2026 8:06 PM
1949 Chevy 3100. Is it better to disconnect the battery when charging? Or doesn't it make a difference?
Ed
It doesn't make a difference.
Slow charging at 1 or 2 amps or less does a better job than fast charging.
I keep all my vehicles on battery tenders. Those all charge at a rate between 750 mili-amps to 1.25 amps. They turn off when the battery is fully charged.
1950 Chevrolet 3100 (Ol' Roy)
I don't see why you can't leave it connected. I know a lot of folks that use a battery tender to maintain the charge on their battery and never disconnect the battery cables from the battery.
~ Dan
1951 Chevy 3 window 3100
AD Addict & Tinkerer
I also keep all of my batteries on Battery Tender’s, without disconnecting. That includes vehicles, boats and yard equipment and I’ve done it that way for more than twenty years, with no issues.
Phil
Project Journals
Stovebolt Gallery Forum
depends on if your engine is HEI. those have an ignition module that unless its a high quality one the module will fry.
BTs maybe not. I dont take chances. If its being stored , battery is disconnected anyway.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Thanks to all for your input. Eases my mind that I won't do any damage by leaving the battery connected.
Ed
But, make sure whatever charger or maintainer you're using stops charging automatically when the battery reaches full charge, unless you're present to turn it off.
Tks for update Otto. Ed
Ed
