5 members (Charles in CA, Gdads51, J Lucas, 78buckshot, walter74), 97 guests, and 3 robots.
Topics128,127
Posts1,056,671
Members48,450
Hello!
I recently installed the Patricks 355 rear end gear set in a 1953 Panel.
Does anyone know if there is a speedo drive that will correct the speedometer?
Seems to be running the speedometer about 5+- slower.
Thank you!
yes, old school speedo shops can make them for you. I think that I also noticed that either JIm Carter, or LMC is now selling them as well.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Joey - You're going to need to invest in a "speedometer adapter" like the one pictured below as probably the easiest way to get your speedometer to read more accurately.
Chevrolet offered a number of these under Parts Group 4.329 - Speedometer Adapter. Those were set with specific correction ratios for adjusting speedometer operation depending on original speedometer drive/driven gears, coupled with the rear axle ratio and tire/rim combinations.
Before you start looking for one, you need to figure out what your adjustment ratio needs to be. Here's a YouTube Video Finding The Right Ratio that can get you started. Once you figure out the ratio needed, you can start looking for folks selling what you need.
The adapters are available from many vendors, including Jim Carter as SP249, which is custom built once you tell them what correction you need.*
Hope this is helpful. wink
*Note - Per the Jim Carter ad, all you need to do is identify your speedometer reading as compared to another vehicle that is confirmed as operating at the correct speed (example - theirs reads 55 and yours 50), and yours will be custom configured to get what you need.
EDIT NOTE - Mike beat me the post button grin
~ Dan
1951 Chevy 3 window 3100
Thank you both for that info!!
I really appreciate it!
Many years ago when I installed my Patrick's 3:55 rear end gears, I had to go thru all this Speedometer reading adjustment. Back then, we had a very local speedometer shop to helped me out but I still had to give them the truck tire reading for a full revolution. The above stuff that Dan provided is it.
Craig
