4 members (Donf, rfs56trk, baldeagle, Oswald), 40 guests, and 1 robot.
Topics128,014
Posts1,055,332
Members48,419
#1600964 04/01/2026 12:51 AM
I was wondering what everyone was using as an overflow tank. The 1946 truck with a 1961 261 leaks antifreeze out the overflow drain after shutting it off. The temperature gauage does not get into the red. TIA
Hank
Hog Wild #1600970 04/01/2026 1:26 AM
A 1946 didn't have an overflow tank. If it is puking coolant after you turn it off, you are overfilling it.
Hog Wild #1600971 04/01/2026 2:13 AM
U
U Offline
But he has a '61 261 engine. Did 1961 come with an overflow tank?
~ John in Utah
Here We Go
Follow in his DITY Bay
Hog Wild #1600972 04/01/2026 2:13 AM
On my 51, 228 it needed an overflow because of the engine coolant level and running hot. I put one on my 302, but it never gets hot and coolant is about two inches below the radiator cap, therefore no need for me. ( Used the stock can type )
Hog Wild #1600974 04/01/2026 3:09 AM
Let it puke out. It will find its own level. Normally it's 1 1/2" - 2" below the bottom of the filler neck - just enough to cover the cooling tubes.
1950 Chevrolet 3100 (Ol' Roy)
Hog Wild #1600975 04/01/2026 4:04 AM
I put this generic $15 version on instead of $140 can style. Function is all right, but not overly thrilled with the look. As others have said probably not needed anyway.
Hog Wild #1600976 04/01/2026 7:43 AM
Overflow tanks allow the pressurized portion of the cooling system to fill completely with coolant, eliminating the air within along with greatly reducing the rate at which the coolant oxidizes/loses its additive package.
Hog Wild #1600979 04/01/2026 9:41 AM
7
7 Offline
If you can keep oxygen out of the cooling system, in theory it will reduce problems. My heater core is above the engine water level and I like to keep the system 100% full of liquid, I added a simple plastic bottle on the back side of the radiator core support where it is out of site, works like a dream to keep the system full. My engine/cooling system never gets too hot, I have to block part of the radiator in the winter, stock radiator/fan/water pump/180 degree stat.
Hog Wild #1600980 04/01/2026 11:40 AM
AD Addict & Tinkerer
The original system didn’t have an overflow tank, but was available as an option or accessory. They’re out there but pretty pricey. Here is one from classic parts.
My ‘52 with a ‘59 235 runs with about a 1/4” above the radiator core. Any more it just pukes it out. I fully agree that a coolant tank is a good idea and one that I’m eventually going to install.
Last edited by Gdads51; 04/01/2026 3:31 PM. Reason: remove tracking from ebay link
Phil
Project Journals
Stovebolt Gallery Forum
Hog Wild #1600981 04/01/2026 11:58 AM
Crusty Old Sarge
Crusty Old Sarge
There are other options, some creative solutions are out there.
Overflow Tank
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Hog Wild #1600982 04/01/2026 12:07 PM
Ol' Roy's previous owner installed an overflow tank. It's on the firewall. I don't like the way it looks but it works so I left it.
Unfortunately for the previous owner, he used the wrong type of radiator cap so the coolant wouldn't return to the radiator when it cooled down.
If you're using a tank, be sure and use a modern style cap with a poppet valve.
Hog Wild #1600983 04/01/2026 12:08 PM
back yard wrench turner
My '38 with a '55 GMC 270 runs a non-pressurized system. I'm using a quart mason jar for my overflow bottle.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Phak1 #1600993 04/01/2026 3:30 PM
Originally Posted by Phak1
The original system didn’t have an overflow tank, but was available as an option or accessory. They’re out there but pretty pricey. Here is one from Classic Parts on ebay.
Phil - Just a note that ordering the same thing directly from Classic Parts 1941-54 Original Style Overflow tank kit (not through ebay) is significantly less expensive, although that doesn't include shipping.
There are also other sellers offering virtually the same kit for less than the ebay Classic Parts kit. I'd just suggest folks do some shopping around as there are some better possible deals for those wanting to save a little. wink
~ Dan
1951 Chevy 3 window 3100
TUTS 59 #1601000 04/01/2026 3:46 PM
That is pretty cool. I don't know if I can get to the bottom of a JD bottle and still be able to install that nicely.
Hog Wild #1601008 04/01/2026 6:02 PM
Insomniac
Insomniac
This has been talked quite a bit over the years. This discussion leads to another:
Previous discussion
Gord 🇨🇦
1954 1/2 ton 235 4 speed
rick46ia #1604507 05/25/2026 10:53 PM
Can you tell me what level do you keep the coolant in the recovery tank?
It’s installed just like one shown in your post and for a 216 engine.
Hog Wild #1604510 05/25/2026 11:00 PM
B Online: Content
An inch or so above the bottom when the engine is cold. Leaves room for expansion and still keeps from sucking air back in as the engine cools down.
Hog Wild #1605879 06/17/2026 4:39 PM
Here’s what I did. Wanted it to have the vibe of something farmer-fabbed back in the day. “Suction” function of it works really well.
It’s an old freezer jar and a repurposed fire extinguisher bracket.
1951 3100
