4 members (GMCJammer51, Shade Baby, greenie-reddy, 2-Ton), 86 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
#1600653 03/27/2026 6:01 PM
What is the correct product to use where the top cab meets the bottom cab. Seam sealer or body putty? Thanks, Grady.
1949 3100
Old Blue
Not sure what the difference is, but I used seam sealer. It's a water based product that's paintable. Seam sealer is flexible whereas body putty (bondo?) is not as flexible.
Thanksfor the info. That's what we were thinking.
1949 3100
Old Blue
Sandblast the snot out of that pinch weld, epoxy prime, use 3M panel adhesive in the groove. Its a 2 part product with self-mixing nozzle.
It sands to a very smooth finish and very solid. When you are done sanding, there should not be much of the product remaining. just enough to fill the gap.
If you address the rust issues properly, this will be a permanent solution. Regular seal sealer would likely not be.
