3 members (Danielbolt, Shade Baby, Youngin' Tut 59), 135 guests, and 1 robot.
Topics128,175
Posts1,057,054
Members48,460
#1600389 03/24/2026 1:09 AM
Hello,
I have what I believe is an SM 318 in my 56 with a 235 engine, and it has started to show a little leakage out of the rear seal. I changed the fluid when I first got the truck almost 10 years ago now and have not needed to add any fluid since. To my knowledge, the transmission has never been overhauled since new; so my question is should I just replace the rear seal, or go ahead and do a overhaul. What would be the best source for kits and information for the work? I have done this once before on a 3 speed on an old Mustang, but that is the limit on my transmission experience.
The transmission does seem to be working fine, so other than a small leak, there appears to be no other problems with it.
Thanks for your thoughts,
Lee
1956 Chevy 3200, 235 w/3 speed
Lee - As long as it's doing its job with only the minor seal leak, I'd just replace that rear seal. Can be easily done in the truck and not disturbing a functional unit IMHO. Back on the road pretty quick to boot. wink
~ Dan
1951 Chevy 3 window 3100
P/N 9613S Output shaft seal available at Auto Zone for about $5.
Fred
Thanks; I will pick one up.
Crusty Old Sarge
Crusty Old Sarge
As long as you're at it , do a good flush and replace your fluid. Just good insurance.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
I ordered a small kit from TPD that also has the gaskets for the side cover; so I can open it up and have a look inside to see what it looks like. Make sure the teeth all look okay and look for metal in the bottom, etc.
If its not giving you any problems then just replace the seal. Even if its missing teeth or whatever and its not acting up just run it. Normally the original New Departure bearings are better than any bearing that come in a rebuild “kit”. I have done a few Saginaw's, Muncie's and my newer T56 and usually the old sloppy transmissions really don't care about much as long as the parts in it are spinning and exist. If its not popping out of high gear then its probably all good.
