7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1600283 03/22/2026 6:44 PM
Going through the cylinder head on 302 (six),
Noticed it did not have any valve seals,
Is a good to install them or not?
Dave
Any have an opinion on this topic?
Original equipment 302 (and 228, 248 & 270) had a small rubber ring (described as "Intake Valve Oil Seal") installed on the intake valves only. GM Part number 2194132. Fel-Pro SS5112 seal set is a replacement. There may be 16 in the Fel-Pro box.
