6 members (RLB, panic, Hotrod Lincoln, dt235sd, Tronman, DougH6100), 123 guests, and 3 robots.
Topics128,201
Posts1,057,280
Members48,467
Page 2 of 2 1 2
Originally Posted by Bill Hanlon
I'll bet your headache is worse now Kevin.
It's actually a bit better. Starting to understand. Thanks, Bill. But what would cause "hyperflashing" with LED's if they have more resistance than incandescent bulbs. There's a lot of talk about adding resistors to an LED bulb circuit. ohwell
I've never seen 'hyperflashing'.
Adding a parallel resistor to led lights should allow a standard flasher to work properly.
U
U Offline
Got some pictures of the clear vs amber light bulbs.
~ John in Utah
Here We Go
Follow in his DITY Bay
Amber looks to be a little dimmer I believe they will do the job. Thanks for the pics
1946 Chevy Truck 216 1/2 ton
"Tales from a weekend mechanic"
Follow in the DITY
I like it with the colour ,is that with amber bulbs or lens.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
U
U Offline
Bulbs
~ John in Utah
Here We Go
Page 2 of 2 1 2
