6 members (rfs56trk, tclederman, Gdads51, Wally / Montana, 39Master85, ndkid275), 100 guests, and 3 robots.
Topics128,132
Posts1,056,376
Members48,441
Hi
Can anyone help, with identifying what models Chevrolet/GM this hood release bracket was used in ?
I need two for my 1941 Canadian Military pattern truck.
Cheers Niels
1941 CMP Chevrolet
12 cab gun tractor
Great exchange in Big Bolts
1946 Chevrolet 5400 COE
132.5" WB
Details in Big Bolts
1944 Scammell Pioneer x 2
Neils, I've moved your post over to Name that part, as it's more on topic there. I'm sure someone will be able to help you with your part ID.
I looked up your year and found two latches but different from the one shown.IT does look like the bracket that attaches to the dash on a 53 truck that the release rod for the emergency brake goes through but I don’t think it was made of cast .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Thanks I was a bit in doubt about what forum section to put it.
1941 CMP Chevrolet
12 cab gun tractor
132.5" WB
Thanks for the reply Kevinski, and correct those are the outer catches for the hood.
The things with these war time CMP Chevrolets are that they really raided the civilian parts bin, and this bracket I am looking for, is on my truck used for operating ventilation flap in the nose of the truck, but I am suspecting that it is originally a hood release
1941 CMP Chevrolet
12 cab gun tractor
132.5" WB
I was thinking parking brake release rod bracket too, but those are stamped sheet metal and much lighter than what Niels pictured.
I have found a part number # 3654573 witch matches an ebay listing, but is there anyway to see what vehicles this have been used in to widen my search ?
1941 CMP Chevrolet
12 cab gun tractor
132.5" WB
3654573 is NOT listed in 1939-1960 GMC Master Parts Books.
Niels V - Lots of different Chevrolet applications, both truck and later ALL passenger cars from 1940-49.* See the screenshot pics below. The file titles show which Chevy Master Parts Books the pics came from.
Hope this is helpful? wink
* Correction from my original information that included trucks as using this piece. Apologies!
Last edited by Gdads51; 03/29/2026 1:35 PM. Reason: correct inaccurate info originally posted
~ Dan
1951 Chevy 3 window 3100
Here is my emergency brake lever rod holder. Looks very similar to what Niels is showing. Will say I could not easily see the flat spot at the bottom of the hole. The hole looks pretty worn. The flat spot on the rod is more at a 3 o'clock position, so yes the rod is not turn quite right, but is still working very well.
Craig
Thank you all, It gives me some more room to search of a set.
Does anyone have a rough estimate what is a fair price for these ?
1941 CMP Chevrolet
12 cab gun tractor
132.5" WB
Niels - No idea what would be considered a "fair price" for one, but I did find a single Bracket being offered on evilbay for $85 plus shipping (YIKES)! I don't think these are that rare, although in your area it's unlikely you will find many vehicles that used these laying around to snag parts from. frown
Perhaps you can post an ad in our Truck Parts Wanted forum. There could be a Bolter or two that can help you out? wink
~ Dan
Hi Dan
Yes I did also see the one for 85$, and with shipping and customs on up it will get rather expensive.
and yes you a very correct there is not much chance of finding one here in Denmark.
Will try the wanted section.
1941 CMP Chevrolet
12 cab gun tractor
132.5" WB
Niels - Just an update note that I corrected my previous vehicle applications information reply above.
I listed the GM# 3654573 as being used originally on Chevrolet trucks too, but on further investigation found they are passenger car only items. As Kevin (klhansen) mentioned above, and others have let me know separately, the bracket for the dash mounted parking brake release that looks similar on the Art Deco and AD series trucks are stamped steel and not cast like the passenger car pieces. They also carry a different part number.
Sorry if my info mislead you and anyone else. frown
I did find a YouTube video showing a 1948 passenger car getting a replacement hood release cable and snagged a picture showing the mount attached to the underside of the dash which I've attached below for informational purposes.
~ Dan
Thank you, I am grateful that you have taken the time to look these things up, Cheers
Niels
1941 CMP Chevrolet
12 cab gun tractor
132.5" WB
Moderated by  klhansen, Rusty Rod
