6 members (68ironhead, WICruiser, TUTS 59, Bill Hanlon, 66flea, 1 invisible), 83 guests, and 3 robots.
Topics128,081
Posts1,056,321
Members48,442
To a big bolt and if so how did it go and how did steering performance change? I’ve been looking around underneath my 2 ton and it seems any of the above add ons would be quite a challenge.
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
I would think you could adapt the Sway Bar from a 3500- 4500 Chevy pretty easily. The radius rods would no doubt take some Head Scratching.
The biggest improvement in handling for me came with addition of front shocks My Truck never had any from the factory.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
I think the swaybar option would be really beneficial in my case. I'd also like to find a pair of brackets for my two ton, for the factory option rear shocks. School bus has none, however my Dad's 60 series (same year, engine, axle, weight rating, etc) had rear shocks on it.
A lot of round track racing rear ends use big steel rings that resemble split shaft collars, with dowel pins that fit holes drilled into the axle tubes to attach sway bars, coilover shock absorbers, 4-link bars, etc. It wouldn't be difficult to fabricate something like that for rear shock mounting points on a big bolt.
That's true, I could make brackets. Probably will end up doing so, it'd just be easy to find a pair of the factory brackets and bolt 'em on.
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
Just post a wanted ad in the "parts Wanted" in the Swap meet. I found my front shock mounts that way.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Well, that's a pretty good idea!
