4 members (DaveV, TUTS 59, Ponchogl, Gib70), 112 guests, and 3 robots.
Topics128,129
Posts1,056,361
Members48,441
#1599223 03/07/2026 4:22 AM
I was unsure which forum would be best, so feel free to move if necessary. I had my speedometer rebuilt, got it reinstalled with new cable. What would be the best product to lube the cable? Would anti-seize work well? Thanks in advance.
Just my $.02 worth, but a graphite impregnated oil like this one from Chev's of the 40's is what I like to use.
I would not recommend using anti-seize compound.
~ Dan
1951 Chevy 3 window 3100
Thanks Dan, any input is appreciated. Think I'll check to see if O'Reily's might have similar product.
I always use the powdered graphite lubricant. It comes in a little tube, I think it's meant for locks because it can't freeze. Just spritz it onto the cable as you feed it into the housing. Works great, lasts for years.
Thanks for the reply!
I have always heard that one should never lubricate a speedo cable, in particular a new one. Any lubricant will ultimately make any dirt stick and impede the rotation of the cable.
'57 Chevy Suburban; '70 Chevy Impala.
I was told by my high school auto shop teacher explicitly never to use powdered graphite on speedo cables.
I was told to use a light coat of white lithium grease if necessary.
People here say to use the graphite impregnated grease which is probably ok since it was likely not around when I was in high school.
When I installed a new cable on Ol' Roy a year or two ago, I put some lithium grease on my fingers and wiped the entire cable. No chunks or heavy deposits, just a light coating. So far so good.
1950 Chevrolet 3100 (Ol' Roy)
Yep, I was gonna say that. Powered graphite should not be used. WL grease or 3+1 oil.
A new cable is around $21 and those would not need lube.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
This IS a brand new cable, and it does need lubed!
Ya, mine was new, too and I installed it as-is and the needle jumped a bit.
I pulled it out and it had no oil or film on it from the factory. Lightly lubed with white lithium grease cleared that right up.
1 Offline
I was taught to use a light coating of white lithium grease also but that was over fifty years ago. I am sure lubricants have improved in that time, but I will stick with what has worked for me.
I guess its the cables bought. I`ve replaced 3 and no trouble . All greased.
Maybe those w/o are cheaper cables...IDK. Dont fix it if it aint broke.
~ BD.
Yep! I thought mine would be o.k. also but when the weather got cold it makes a bunch of racket and the needle becomes erratic.
