4 members (fonz8261, Hotrod Lincoln, TexasJim50, 1 invisible), 94 guests, and 2 robots.
Topics128,134
Posts1,056,416
Members48,441
#1598798 03/01/2026 1:56 PM
I have this broken spear. Clean break. What the best way to repair? 2 part epoxy or JB weld? any suggestions?
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Maybe both? A 2 part epoxy for the broken joint, clear to reduce visible repair. Then once that's cured, lay it face down and layer some JB Weld on the back side, kinda like a bandaid. There's a nice recess on the back side where you could actual smear a couple of thin layers to give the crack repair some stabilizing/rigidity.
~ Dan
1951 Chevy 3 window 3100
Thanks. I have both. I`ll give it a try.
~ BD.
