0 members (), 144 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
Page 13 of 13 1 2 … 11 12 13
First attempt at protecting the rad is by using some window/door screen replacement. Not sure if this will pan out but it’s worth a shot since a 48”x118” piece was $12 cdn.
Looking at the truck and figured I can use this stuff on my cowl vent as well.
1940 1/2-ton
Low skill and low buck build
Follow in the Project Journals
In the dark of night, she's a looker.
U
U Offline
I've never thought about protecting the radiator, but since I have a new one maybe I should think about it now.
~ John in Utah
Here We Go
Follow in his DITY Bay
How many times has a radiator in any vehicle you've ever driven in your entire life been damaged by things flying into it? Probably never. Don't worry about trying to solve a problem that doesn't exist.
32vsnake drag races his truck and drives it hundreds of miles to get to the races.
1950 Chevrolet 3100 (Ol' Roy)
Found and posted some photos from the 2025 Drag and drive event.
2025 BC dragit challenge
Taking this year off from the drag/drive to do the BC hot rod tour and to make some changes to the truck.
1940 1/2-ton
U
U Offline
Fun pictures. Thanks for sharing.
~ John in Utah
Here We Go
Small update but 1 that was long overdue. Somehow I lost the fast idle rod when changing the main jets… that was close to a year ago.
Picked up some Round Aluminum Rod, 2.5mm (1/10") Dia and bent it to shape.
Cold truck, choke fully engaged and it flashed right up. Idle sits at 1000rpm and I no longer have to do the throttle dance to keep it alive until it warms up
1940 1/2-ton
Was an amazing way to enjoy the old truck. I had a blast and will be doing more of these events going forward. It’s kind of addictive grin
1940 1/2-ton
That custom shaped aluminum radiator looks.. not low buck. I'd invent a way to protect it, too. I think I will do this screen trick on my rig too, to protect the expensive new alloy heat exchanger I installed.
I always used to put a screen in front of the radiator to protect it from mostly the bugs 🐛.I was told that the bugs are corrosive when they get squished in the rad and start to eat away at metal ,the screen stops them from getting in the fins and makes it easier to spray off with the hose.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Little more screen door experimentation… attempting to create a bug screen for the cowl vent.
Mocked it up with some magnets and used 3m weather strip and gasket adhesive to hold it in place…
1940 1/2-ton
U
U Offline
I like the screen on the cowl vent. Now if you can keep the bugs from coming in when the windshield is open! 🙂
~ John in Utah
Here We Go
When I open the driver's side vent, I sometimes get hit in the leg with bees and other stuff.
Moderated by  Phak1
