Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
I believe this has been mentioned before but I was unable to find it.. What is you Bolters prefferd grease and grease gun that doesn't leak to service your Stovebolts?
In my experience, they ALL leak. But the pistol grip style is the easiest to use. My son-in-law insisted on one of these to grease his skid steer.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
I have two pistol style grease guns that used to belong to my dad. One is the standard size tube and the other is the small size tube.
They're both from the 1960s or 70s I'd imagine. I think one might even be a JC Penny Penncraft. Neither one leaks.
I've installed a flexible hose like the the DeWalt pictured above has and it works great.
I'd try to find an old one for sale on ebay.
1950 Chevrolet 3100 (Ol' Roy)
I've had the same Made In USA blue Lincoln 11oz cartridge loaded grease gun since sometime in the early '90s. It doesn't leak after most of a decade in daily mechanic use, now I use it in the bicycle shop and for my own and friends' vehicle maintenance.
When my pistol grip style gun broke, I switched to the DeWalt like Kevin and Mark. Its great! After using grease guns a lot in the shop and out on job sites, I don't believe any you who claim your grease gun doesn't leak or make a mess. The DeWalt goes through a tube faster, though ...
"Grease on the floor is money out the door"
JM
~ John
1949 Chevrolet 3804 In the Legacy Gallery | In the Gallery Forum 1973 IH 1310 Dump 1963 Kaiser M38A1 2001 International/AmTran RE3000 "Skoolie" 2014 Ford E-350 4x4 (Quigley)
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
